- #36
gracy
- 2,486
- 83
What are these pictures about?
I don't think so. If Q1 is greater, then only Vxf>Vyf. You can see it here.gracy said:And even if Q1 isn't greater final potential at x will still be greater than final potential at y. Right?
See #37. The polarity of 10uF has changed. If Q1 is more, it will retain its polarity.gracy said:##q_{1f}## + ##q_{2f}## =##Q_{1f}## - ##Q_{2f}##
If ##Q_{1f}## < ##Q_{2f}##
It means ##q_{1f}## < ##q_{2f}##
But it does not tell much about polarity of ##q_{1f}##.
cnh1995 said:eater, Vxf>Vyf. In #37, Q1(charge on 10uF)is less than Q2(charge on 5uF). Hence, polarity of C1(10uF) changed, making Vxf<Vyf.
If Q1<Q2, Vxy will be negative i.e Vx<Vy.gracy said:There will be potential difference between points x and y given by (Q1−Q2)/(C1+C2)
It is a simulation result. It is an example of the case 3 in that video. In that circuit, Q1(charge on 10uF) is less than Q2(charge on 5uF) but initially Vx>Vy. When the middle switch is closed, it becomes the case 3. You can see the polarity of the 10uF reversed in the steady state, making Vx<Vy.gracy said:I am unable to comprehend those pictures in post #37.
It is an android app on my phone.gracy said:Can you give me link to that simulation site?
I thought it was clear to you as to why Vx > Vy . ##\ ## After all, Vx − Vy = (Q1 − Q2)/(C1 + C2) .gracy said:There will be potential different between points x and y given by ##\frac{Q1-Q2}{C1+C2}##
Right?
They are the very same thing in this case.gracy said:I thought this formula is for potential difference and it is not particularly ##V_x## - ##V_y## rather ##V_+## - ##V_-##. I know it's bit odd but that's what I thought.
First, think.gracy said:When I thought it is ##V_+## - ##V_-##
By ##V_+## I mean potential at either x or y whichever is at greater (positive potential ).
(##Q_1## - ##Q_2##)/(##C_1## + ##C_2## )This formula just gives potential difference and does not specify anything about which point is at greater potential.This is what thought.
I wrote there will be potential different between points x and y given by (##Q_1## - ##Q_2##)/(##C_1## + ##C_2## ) because at that time I knew x is at greater potential.
