Question: do e/b-fields effect light?
  • Thread starter Thread starter silverdiesel
    Light
Light, as an oscillation in electric (E) and magnetic (B) fields, is not distorted in a vacuum due to the principle of superposition. However, in media, light can be influenced by E fields through the electro-optic and Kerr effects, which alter the refractive index and can deflect light. B fields can affect light via the magneto-optic effect, causing polarization rotation in a medium. While classical electrodynamics suggests no interaction in a vacuum, Quantum Electrodynamics (QED) predicts that at extreme field strengths, light can interact with electromagnetic fields, leading to phenomena like light-light scattering. Understanding these effects reveals the complexities of light behavior under various conditions.
silverdiesel
If light is an oscillation in the E and B fields, then, if you sent light thought a capacitor, why doesn't the E-field of the capacitor somehow distort the light? And why doesn't the B-field of the Earth, or powerlines distort light?
any insight appriciated.:confused:
Science news on Phys.org
In a vacuum, there is no distortion, due to the principle of superposition. Inside media however is a different story. Since the response of atoms within a medium is nonlinear to some degree, the principle of superposition does not hold.
Light can be influenced (Probably a better word than distortion) by an E field inside a medium via either the electro-optic effect or the Kerr effect. The Electro-optic effect is a variation in refractive index with E, thus such an effect can be used to deflect light. The Kerr effect is a similar effect, but has a slightly different dependence on E.
Light can be influenced by a B field via the magneto-optic effect. An applied B field causes the polarisation of a light beam to rotate as it propagates inside a medium.
Typically though, for either of these effects to be readily observable, one needs to use hundreds to thousands of volts, or a magnetic field a sizeable fraction of a Tesla.
Claude.
Although Claude Bile gave an excellent answer, valid for all everyday situation and more thereon, I would like to add that at extreme intensities modern theory actually predicts that even in vacuum light can be affected by electromagnetic fields.
Classical electrodynamics obeys Maxwell's equations, which are linear in vacuum, and hence superpostion holds, just like said above. Hence EM-fields cannot interact classically. However, according to Quantum Electrodynamics (QED), there are small non-linear corrections to Maxwell's vacuum equation, allowing EM-fields to interact with each other. That is, QED predicts for instance light-light scattering and light-(E-field) scattering, the later being observed in so called Delbrück scattering (see e.g. G. Jarlskog et al., Phys. Rev. D 8, 3813 (1973)), where light is scattered by the E-field outside a heavy nucleus.
Anyway, again note that those QED-effects only appear at extreme field strengths.
Interesting. I am very glad to hear that. It seems as you learn more about light, your intuition is always wrong. So I am glad to see that what seems to be true, is actually true even if only at very lage E and B magnitudes.
Thanks for the responces.
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
Thread 'How to model converging illumination through object plane (in ZEMAX)'
Hello community, I'm designing a projection lens system for a 35mm film projector in Zemax OpticStudio and struggling with the correct sequential mode setup for the illumination geometry. The light source is a Xenon short-arc lamp reflected by an ellipsoid mirror, which creates a converging cone with a 40.6 degree full angle that passes through the film gate. The film gate is my object plane, but the light doesn't diverge from it like a typical Lambertian source. Instead, the converging...
