I Question for large quantum system
JasonWuzHear
I'm trying to understand the concept of uncertainty in relation to derivatives for a large quantum system, i.e. one with many degrees of freedom.
When is it true that σE/σt ~ dE/dt? ---- 'σ' is the uncertainty
First, I know there is no time operator in quantum mechanics. I'm not sure how to work around that, perhaps we could try the question with momentum and position. The point is, for a large quantum system, can I approximate the rate of change of energy with the uncertainty of energy divided by the uncertainty of its age?I've tried unconventional methods to answer the question. First using an assumption that:
i/ħ d2/dt2 ψ = dE/dt ψ
then trying to compare it to the uncertainty calculation assumed as follows:
(σE)2 = (∫ ψ*Eψ dt)2 - ∫ ψ* E2 ψ dt
Which gives equal results for a Gaussian wave function. But I'm not sure how to go about this question in a more conventional way.
Why do you think this should be true at all?
I was thinking of a couple reasons why it might be true.
For one, there is the Griffith's proof that Exact decoherence implies conservation of quantities that commute with the Hamiltonian. Exact decoherence in energy states is not different than saying the quantum uncertainty in energy is zero (there can still be some classical probabilities). This leads to the idea that when
dE/dt = 0 ⇒ σE = 0
which means that
σE/σt = 0 for σt ≠ 0
Additionally, if we take the momentum operator, P
if σP = 0, then
(P) (P) Ψ Ψ = (PΨ)2
and
σP/σx = 0 for σx ≠ 0
the particle is not influenced by a potential in this scenario, and momentum is conserved through space translations
dP/dx = 0
So it at least seems true to me for when the system conserves energy.
You can define the uncertainty as the average deviation from the mean value when the system collapses in that basis. If you take a system, periodically measure its energy with a period, T, and allow it to grow in energy uncertainty, σE, in between measurements, then the change in energy over time on average will be:
<dE/dt> = σE/T
I feel like there ought to be some relationship between T and t relating to the success of the measurement. If σt is much larger than σT, then the measurement is less likely to succeed. The larger your T, the larger σE can grow. This makes me want to multiply the thing above by (T σT)/(σt) if the probability of measurement success, Ps, is proportional to σT/σt which gives
σE = ("σE")T the energy uncertainty in quotes is some value not dependent on T
Ps ∝ σT/σt
<dE/dt> ∝ "σE"σT/σtThat's all I've got so far
JasonWuzHear said:
Griffith's proof that Exact decoherence in energy states is not different than saying the quantum uncertainty in energy is zero
Are you referring to the proof discussed in section 2 of this paper?
https://arxiv.org/pdf/gr-qc/9410006.pdf
I read Hanbury Brown and Twiss's experiment is using one beam but split into two to test their correlation. It said the traditional correlation test were using two beams........ This confused me, sorry. All the correlation tests I learnt such as Stern-Gerlash are using one beam? (Sorry if I am wrong) I was also told traditional interferometers are concerning about amplitude but Hanbury Brown and Twiss were concerning about intensity? Isn't the square of amplitude is the intensity? Please...
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
