Question on electromagnetic repulsion
The user has created a simple electromagnet using an iron nail, insulated copper wire, and a 9v battery, but is experiencing attraction instead of the desired repulsion with a small permanent magnet. They suspect the issue may stem from the strength of the permanent magnet overpowering the repulsive force. Suggestions include providing more details about the magnet's dimensions and using a more suitable power source, like a 1.5 D cell, to improve performance. The user notes the permanent magnet is circular, about 1 inch in diameter and 1/4 inch thick, while the nail is 6 inches long. The discussion emphasizes the importance of wire length and coil density for effective electromagnet functionality.
willynilly
I have made a simple electromagnet with an iron nail, insulated copper wiring, and a 9v battery. My intention is to use the electromagnet to repel a small permanent magnet, but for some reason, I can only get the electromagnet to attract the permanent magnet. I figure I must have a problem with connecting the poles (S to S or N to N.)
I'm thinking maybe this is happening because the force of the permanent magnet being attracted to the nail is greater than the force of the magnetic repulsion.
Any suggestions? What can I do to get repulsion?
Thanks
An object cannot be attracted, but yet be repealed at the same time. You should have at least posted some dimensions of the magnet (length, width, mass, etc.) and the type of battery that you are using and the current that it delivers.
Because of the resistance of copper wires, you are much better off getting a 1.5 D cell for your power source. 24 Ga copper wire is about 38 ft per ohm, so you should use about 100 ft for your coil.
The permanent magnet is circular, about 1-inch diameter and about 1/4 inch thick. It's not very powerful.
The nail is 6 inches long. I have no idea how many feet of wire I used or how many coils, but the entire thing is covered.
Hopefully I have a 1.5 D cell laying around somewhere that I can try out.
Thanks for everyone's help.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
