Question on Thermal Siphoning velocity?
  • Thread starter Thread starter derekpearcy
    Thermal Velocity
A new forum member, passionate about solar research, has developed the Pearcy Solar oven, which can reach temperatures of up to 410 degrees Fahrenheit using infrared light. They are also working on efficient solar heaters utilizing thermal siphoning to circulate air, achieving a temperature increase of 70-100 degrees above the surrounding air. The member seeks information on the speed at which hot air rises, acknowledging it likely depends on temperature differences and air density. Another participant suggests that measuring the rise could be accomplished through a DIY apparatus, such as a pinwheel, to gauge the speed of the hot air. Overall, the discussion centers on practical applications of solar heating and the physics of hot air movement.
derekpearcy
Hello everyone, I'm new here, so this is my first post on here. I've never taken a physics class in my life, but love the stuff. I'm an avid solar researcher. Not photovoltaic panels, but more in the infrared spectrum since that compromises nearly 50% of the light from the sun and could be very useful. Thus far, I've created the Pearcy Solar oven, which can be used for cooking with sunlight only, and reaches temperatures of up to 410 degrees here in Illinois.
I'm also working on building more effecient solar heaters for my home as well. I'm using the thermal siphoning technique to circulate air through them. Hot air comes out of the top of the unit, which pullls more cooler air in thru the bottom. The question I have is the feet per second or feet per minute at which hot air will rise. I'm sure it highly revolves around the temperature difference, but I'm not sure.
I'm getting anywhere from 70-100 degrees warmer than the surrounding air coming out of the top. Any ideas at what speed this will rise? Thanks!
Derek
Science news on Phys.org
Derek
Derek, I can't actually answer your question, because I don't possesses the necesary knowledge myself, but I will offer a generality and pose a question.
I would suspect it would depend on the change in temperature the air experienced coupled with some coefficient that describes how air expands when heated. And the density of the air into which it was expanding...
Now my question is, can you build an apparatus to actually measure it? I mean, you are clearly proficient in building things, so a guy like you should me able to devise a way to physically take a measurement. Perhaps the number of RPM a pinwheel of know radius can be counted?
You can actually see the heat rising on the floor inside. So I covered the opening, then opened it quickly, and then marked the distant the visible heat traveled in 1 second. It was about 2 feet, so I guess its going to rise at about 2 feet per second... But this isn't anything official, that's what I was after.
Problem: You’re an Uber driver with a Tesla Model 3. Today’s low: 30F, high: 65F. You want to reach a USD$ profit target in the least number of hours, but your choices could have added cost. Do you preheat the battery only when you are headed to the charging station (to increase the charging rate by warming the battery — however the battery might not be “warm enough” when your reach the charger and thus slower charging rates), or do you always “navigate to the charger” the entire day (which...
