B Question: Orbital mechanics of a binary star system
Binary star systems, such as Sirius A and B, can be analyzed using principles similar to Kepler's laws, specifically through the two-body problem framework. The motion of two stars can be described using conic sections, and Kepler's third law applies with modifications for the combined mass of the two stars. Both stars orbit their common center of mass, and the displacement vector between them can be treated as if one star is "nailed down" for simplification. This approach allows for accurate calculations of total energy and angular momentum, while still acknowledging that total momentum is not conserved in this non-inertial frame. Understanding these dynamics provides a solid foundation for tackling binary star system problems in physics.
mathisrad
TL;DR Summary
What are the basic principles/equations for orbital mechanics of a Binary star system?
I was reading about how Sirius A and B were part of a binary star system, im familiar with the concept of binary star systems and even a little bit of how they discovered, as well as spectroscopic and eclipsing binary star systems. However, I still dont know how to calculate period or just general information about binary star systems, as if it was on a test. Is there any set of equations (kindve like keplers laws but for binaries) That I can learn to be more comfortable answering more math based questions on binary star systems? (Also the competition I need to learn this for says its a undergrad level, but I'm posting this in High school physics because I also need to learn the basics, not just the more advanced stuff)
Astronomy news on Phys.org
The motion of two bodies of comparable mass far from other similar masses and far enough away from each other to not have other interactions than gravity, is called the two-body problem and solutions to that should approximate well the relative motion of (isolated) binary star. The geometry of the relative motion for two-body problems are called conic sections since they trace out the intersection between a conic and a plane. The solution even have same "structure" as Kepler orbits, except that the general solution use the so-called reduced mass. So what you know from Kepler's law should also hold approximate true for (isolated) binaries.
Thanks this was really informative
BTW, Jupiter is large enough to treat Sol-Jupiter as a two-body problem. The S-J barycenter is about 49,000km above the Sun's surface.
To shorten the somewhat long and confusing Wikipedia article: yes, binaries obey Kepler´s laws.
About the application: you may follow their movement around the empty and invisible centre of mass - or you may simply follow the movement of star B relative to star A.
Watching the movement relative to (either) star seems to give the simpler solution.
Kepler´s third law is
t2=C*a3/M
where a is the semimajor axis.
For binaries where both bodies have significant masses, the third law still holds if you measure a between the two stars and the M has to be the combined mass of the two components. That simple.
And to add to that, not only does Kepler's third law about the total motion (its period and semimajor axis) apply, so does Kepler's first and second laws! The laws all apply to the motion of the displacement vector between the two bodies (so now we have left high school but you said you wanted more advanced information, the displacement vector is nothing more than an arrow that extends between the two objects, it only has a length and a direction, there's no necessary meaning to where it is anchored). All you have to do is imagine that one body with a gravitational mass equal to the total mass M1 + M2 is "nailed down", and the displacement vector connects it to the other body, moving under that gravity in exactly the way an object would if the other one was not able to move. Indeed, this is precisely the situation where all three Kepler's laws apply.
Digging a little deeper, we should notice that in binary stars, we can't really assume either star is "nailed down" (the way we invariably do for the planets orbiting a "nailed down" Sun, which is the language we use with Kepler's laws in our solar system). Instead, both stars orbit the center of mass, so does this mean our new version of Kepler's law is only approximate, whereas it is accurate in the solar system?
No, all three Kepler's laws still completely apply to the displacement vector between the two bodies. What's more, you can even get total quantities like the potential energy, kinetic energy, and total angular momentum if you imagine that the orbiting body at the outer edge of the displacement vector (the "head" of the arrow, if you will) has a mass equal to the "reduced mass", M1 * M2 / (M1 + M2). Everything is exactly like you were taught about Kepler's laws, except you pretend you have an object of mass M1 * M2 / (M1 + M2) orbiting a nailed-down object of gravitational mass M = M1 + M2. You get right all the total energies and the angular momentum too. The only thing you get wrong is the total momentum, which is not zero for the orbiting reduced-mass object (but of course is zero in the center of mass frame for the real system, so it's obvious you are getting that wrong and wouldn't need to try to use that quantity anyway).
And here's a bonus, you even get one thing right about Kepler's first law that is wrong in the usual way you were taught it. I'll bet you were taught that orbits are ellipses with the Sun at one focus. That's only approximate, and works because the Sun's mass is so much more than the planets (so it's no good for binary stars). As pointed out above, the Sun is not at the focus of the ellipse of Jupiter's orbit, it is the Sun-Jupiter (ignoring all the other planets for simplicity) center of mass that is the focus of both Jupiter's ellipse and the Sun's ellipse (which of course are very close to circles, but didn't have to be). Also, neither of those ellipses have their semimajor axis equal to the maximum distance between the objects. But if you use the description where all you track is the displacement vector between the two stars in the binary (or the Sun and Jupiter), then that vector traces out a single ellipse whose semimajor axis is the maximum distance between the objects, and the "nailed down" hypothetical object really is at one focus, unlike the Sun.
In short, this is actually the situation you have been taught all along, but didn't know it until you started thinking about binary stars.
To dig even deeper, we are always allowed to "nail down" (in effect) one of the objects, simply by choosing a coordinate system where that object is at the origin of the coordinates (which is the only thing that nails it down, it's not something physical just a choice of perspective) and if you do that, these objects with the displacement vector between them are not hypothetical at all. That is not an inertial reference frame (which is why the total momentum is not conserved in that frame), but what we are saying is you can handle all the tricky non-inertial business by completely ignoring it, if you simply treat the object that is nailed down as if it had a gravitational mass of M1 + M2 (and an effectively infinite inertial mass, as it's nailed down by the coordinates), and the object that is orbiting as if it had a gravitational and inertial mass of M1 * M2 / (M1 + M2). This is a wonderful simplification of the two-body problem, and it works for any M1 and M2. As mentioned, you even get the total energies and angular momentum right, which is quite convenient.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
How does light maintain enough energy in the visible part of the spectrum for the naked eye to see in the night sky. Also, how did it start of in the visible frequency part of the spectrum. Was it, for example, photons being ejected at that frequency after high energy particle interaction. Or does the light become visible (spectrum) after hitting our atmosphere or space dust or something? EDIT: Actually I just thought. Maybe the EM starts off as very high energy (outside the visible...
