Question Regarding Capacitance And Inductance
To find capacitance using initial charge, inductance, and energy, the formula C = ½ Q² / E can be applied, where Q is the initial charge and E is the energy stored. The discussion highlights that knowing the initial charge and energy is sufficient to compute capacitance. The relationship between capacitance and voltage is also noted, with V = Q / C. The circuit in question consists solely of a capacitor and a solenoid. This approach provides a clear method for calculating capacitance in the given context.
bobbles22
Hi there,
I'm doing a home study course including a section on dynamic fields and waves. I am trying to understand how to find capacitance using initial charge, inductance and energy.
From a previous section, I know I can find the maximum current using Um=1/2 LI2
However, I can't see how to find the capacitance. Can anyone point me in the right direction please.
Many thanks
Bob
bobbles22 said:
Hi there,
Many thanks
Bob
What does the circuit look like? Can you upload a PDF?
Knowing the initial charge and energy should be enough to compute capacitance.
From the definition of capacitance, C = Q / V
therefore V = Q / C.
We know that the energy stored in a capacitor is, E = ½ C V^2
therefore E = ½ C (Q/C)^2
so E = ½ Q^2 / C
hence C = ½ Q^2 / E.
Its a simple circuit with just a capacitor and a solenoid, nothing else
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
