Question Regarding Operational Amps
  • Thread starter Thread starter ZxcvbnM2000
    Amps
An inverting summing amplifier can accept both positive and negative input voltages, such as V1>0 and V2<0 and V3<0, provided the op-amp operates from split power supplies (e.g., +/-12V). The key is that the sum of the input voltages must remain within the op-amp's input voltage range. Most summing amplifiers function by summing currents through high resistances at a virtual ground, allowing for flexibility with input voltage signs. As long as the overall current sum is positive and within the op-amp's operating parameters, multiple input voltages can be utilized effectively. This setup allows for various combinations of input voltages without compromising functionality.
ZxcvbnM2000
Hello ,
i would to ask if it is possible for an INVERTING summing amplifier of three input voltages ( V1,V2,V3) to have some of them negative and some positive i.e V1>0 and V2<0 and V3<0 or any other combination.
Thank you !
ZxcvbnM2000 said:
Hello ,
Thank you !
That should be okay, as long as the opamp is running from split power supplies (like +/-12V), and the input voltages sum to a value that is within the input voltage range of the opamp.
Thank you :)
Most voltage summing amps are 'really' summing currents through high resistances at a 'virtual earth' so it may not matter that some of the voltage contributions are negative when the PSU is only positive and earth, as long as the sum of currents is greater than zero. That's just the equivalent of current biasing the input appropriately and getting yourself a level shift, effectively.
In principle you can have as many input (+/-) voltages as you like as long as their result is within the operating parameters of the op amp...power supply etc
Yes - that's a good way of putting it.
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
  • · Replies 18 ·
