Question regarding Supernova SN1987
  • Thread starter Thread starter Oblivion
    Supernova
Supernova SN1987A's surrounding gas ring is a result of the star's explosion, specifically from the outer layers being ejected during the core collapse. The gas ring becomes more visible as the shockwave approaches due to the recoil effect from the collapse, which imparts significant energy to the gas shell. The difference in velocity between the gas ring and the shockwave can be attributed to this energy transfer, allowing the gas to expand outward ahead of the shockwave. The initial collapse leaves the outer atmosphere behind, which is propelled outward as the core collapses. For further details, resources on Type II supernovae provide additional insights into the dynamics of SN1987A.
Oblivion
I have a question regarding Supernova SN1987A. I was wondering if anyone could tell me if the gas ring that surrounds it was the result of the explosion itself, or if it was there prior to it?
Astronomy news on Phys.org
It's the result of the star going supernova. As the core collapses, the outer layers of the star are ejected.
Ok that's what I figured, but this brings up another question: the gas ring is supposed to become more visible as the shockwave approaches. However, I was wondering how the gas ring got outside the shockwave in the first place, and why is there a difference in velocity between the two?
When the core collapses, there is a recoil effect. In a supernova, this gives the gas shell a huge jolt of energy. Bear in mind, the initial collapse basically leaves the outer atmosphere as an abandoned child [when the core of the sun collapses, the outer shell will be outside the orbit of the Earth and the collapsed core will be about the same size as earth]. The aftershock of the core collapse propels the atmosphere.
This site here: http://www-astronomy.mps.ohio-state.edu/~pogge/Ast162/Unit3/supernova.html gives a good explanation of Type II supernovae (like 1987A) and even explains the expanding gass shells and shockwave as you are discussing.
Lower down the page, SN 1987A in particular is discussed.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
