Question regarding What is the universe made of?
  • Thread starter Buzz Bloom
  • Tags
    Universe
In summary: I see it now. I'm not sure why the link doesn't work for you. It works fine for me. But if you are concerned about the link, you should not click on it. I'm not sure what to suggest.In summary, the article discusses the missing baryonic matter in the universe and explains that it is likely located in diffuse intergalactic gas clouds, with temperatures ranging from 100,000 to 10 million degrees. This temperature is largely due to collisional heating caused by gravity, and the gas is so diffuse that it takes a long time for it to cool through radiation. The majority of this gas was ionized by radiation from the first stars and quasars, and
Buzz Bloom
467
The link below is to an 12/2/15 article at phys.org titled:
What is the universe made of? Shedding light on the mystery of missing ordinary matter.
http://phys.org/news/2015-12-universe-mystery-ordinary.html
Here is a quote:
Numerical simulations made it possible to predict that the rest of this ordinary matter should be located in the large-scale structures that form the 'cosmic web' at temperatures between 100,000 and 10 million degrees.​
The article explains a lot about the missing baryonic matter, but does not explain why these intergalactic gas structures should have such large temperatures. Can someone offer an explanation about this?
Regards,
Buzz
Astronomy news on Phys.org
The article is discussing intergalactic gas clouds that are not yet dense enough to form stars or galaxies. The temperature is largely the result of collisional heating due to gravity. The gas is quite diffuse so, not unlike the solar corona, a little energy goes a long ways.
Hi @Chronos:
Thank you for your answer.
I can understand that as a body of gas contracts into a smaller volume because of internal gravitational effects, its temperature and pressure would rise. What still puzzles me is why such temperatures would not have dissipated itself through radiation before reaching an ionization temperature. I suppose that when the temperature raises sufficiently for the gas to become ionized, that the photons would be unable to escape continual interaction with the ions. But, in the earlier stages of collapse, before ionization, why didn't the increases in temperature dissipate through radiation well before the temperature reached the ionizing range?
Regards,
Buzz
The majority of the intergalactic gas in the universe was ionized by energetic radiation from the first stars and quasars approximately 150 million years after the big bang. So the collisional heating that Chronos is referring to is acting on this ionized gas (plasma). This plasma does cool through radiation, but for very hot diffuse gas, the time for it to cool can be very long, longer than the lifetime of the universe.
Likes Buzz Bloom
This might be a silly question, but what makes single (##m^{-3}##) ionized atoms hot? The articles are mainly about why it's been detected and that it's called WHIM. How are the ##10^7 K## explained? The only hint I read was "This gas has been heated up by the cluster's gravitational pull and is now feeding its core." I can't match this with this extremely low density.
Hi phyzguy:
Thanks for your post. I much appreciate your very clear explanation. Can you site a reference that gives the math for this result?
I also looked at
Here is a quote that bothers me.
"Evidence for the WHIM is really difficult to find because this stuff is so diffuse and easy to see right through."​
If the gas is easy to see through then presumably it is transparent to the photons that would dissipate the high temperature. Does that make sense?
Regards,
Buzz
Chronos said:
For the orginial paper see http://arxiv.org/abs/1512.00454, Warm-hot baryons comprise 5-10 per cent of filaments in the cosmic web.
Hi Chronos:
Thanks for your post with the interesting link.
Regards,
Buzz
Buzz Bloom said:
Hi phyzguy:
The classic reference is "Radiative Processes in Astrophysics", by Rybicki and Lightman. Hot ionized gas like this cools primarily through thermal bremsstrahlung. A good set of online slides on this topic is at this site. Slide 3 gives the cooling time of the hot plasma, which is proportional to sqrt(T) / n. For galaxy clusters it can by 10 Gy or more. The gas is so diffuse that it is quite transparent, so the cooling photons leave easily. Realize that an ion traveling along at high speed will not radiate, it only radiates when it collides with another ion. And in hot, low density plasma, collisions are rare enough that it takes a very long for a given ion to lose much energy.
I'm not sure I understand your question. The ions gain energy as they fall into gravitational potential wells. They are hot because they are moving at high speeds. Velocities in galaxy clusters are typically 1000's of km/sec. Ions flying around at 1000 km/sec have a temperature of 10^7 - 10^8 K. The density is low, so the ions only collide rarely, but they do collide and share energy to maintain a roughly thermal distribution.
Yes, that was my question. Thank you.
Hi phyzguy:
Thanks for the reference
Firefox doesn't like the link "at this site." It complains as follows:
This Connection is Untrusted
You have asked Firefox to connect securely to www.astro.rug.nl, but we can't confirm that your connection is secure.
Normally, when you try to connect securely, sites will present trusted identification to prove that you are going to the right place. However, this site's identity can't be verified.​
I find that Firefox is more protective regarding security matters than other browsers.
Regards,
Buzz
Buzz Bloom said:
Hi phyzguy:
Regards,
Buzz
its linking directly to a PDF file ... my various anti virus etc progs gave no warnings
you should be OK to continue to the file
the maths in the paper is way over my headDave
Buzz Bloom said:
Hi phyzguy:
Regards,
Buzz
Oh, well. You get what you pay for. My copy of Safari didn't complain. I have downloaded the file and I doubt there is a security issue, but I make no guarantees. I uploaded a screenshot of the relevant pages
Hi phyzguy:
Thanks for the post.
I did download the PDF file, and the math is over my head too. But it does show that someone did calculate the long time required to dissipate the high temperature.
Regards,
Buzz
Related to Question regarding What is the universe made of?
1. What is the universe made of?
The universe is primarily made up of matter and energy. This includes elements like hydrogen, helium, and various forms of radiation such as light and cosmic rays.
2. Is there more than one type of matter in the universe?
Yes, there are four known types of matter in the universe - ordinary matter, dark matter, antimatter, and exotic matter.
3. How much of the universe is made up of dark matter?
Scientists estimate that about 27% of the universe is made up of dark matter, which cannot be seen or directly detected. Its existence is inferred through its gravitational effects on visible matter.
4. What is the role of dark energy in the universe?
Dark energy is believed to make up about 68% of the universe and is responsible for the accelerated expansion of the universe. Its exact nature and origin are still largely unknown.
5. Can we create or destroy matter in the universe?
No, according to the law of conservation of mass-energy, matter and energy cannot be created or destroyed, only converted from one form to another. This means that the amount of matter and energy in the universe remains constant.
