I Questions about a Laser Interferometer pattern
An interference pattern can be achieved even if the original laser beam is not split before reuniting, as long as the light maintains coherence. Using two mirrors separated by 2 cm to reflect light from a 500-meter distance can create an interference pattern similar to that of a Michelson interferometer. The pattern will indeed change if one mirror is moved by half a wavelength. The coherence length of a typical laser beam is crucial for this setup, as it determines the maximum distance over which the light waves remain correlated. Overall, careful alignment and control of the mirrors are essential for observing the interference effect.
snuz2001
TL;DR Summary
Interference without splitting
Is it possible to get an interference pattern if the original laser beam is not splitted before reunited? Can I use 2 mirrors which will be separated 2 cm from each other and they reflect the light from the incident ray 500 meter far which is then reunited to get an interference pattern on a screen, so if I’ll move one mirror half wave length the interference pattern will change on the screen?
What is the coherence length of a typical laser beam?
https://en.wikipedia.org/wiki/Coherence_length
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
