- #71
stefan r
- 310
You are right, that was the wrong sentence. Sorry. You probably understood it fine but I am not convinced someone reading it will.Drakkith said:The part of my post that you highlighted refers to the non-degenerate shell, not the degenerate core.
Anything at a given radius has the same gravitational pull from a same mass object regardless of the object's density. The core contraction allows plasma from the shell to fall in. At the lower radius the plasma has a higher temperature.This contraction increases the gravitational pull on the shell of hydrogen just outside the core.
If I understood it correct then there is no difference between the fusion in the non-degenerate shell and main-sequence stars. Identical temperature and pressure would spawn identical fusion rates.
High metal stars are more compact when they form and burn hydrogen faster. The core burns hydrogen faster as helium increases (assuming total mass stays the same). The older core would continue ramping the burn rate exponentially except that degeneracy pressure delays or stops the collapse.
Hypothetically, if degeneracy pressure did not exist would the sun burn straight to iron and a planetary nebula or would it form a micro-black hole?
