Questions for the conceptual design of an avalanche protection structure
  • Thread starter Thread starter hellophysics
The discussion focuses on the flexibility of joints between gluelam beams and reinforced concrete columns in the context of avalanche protection structures. A flexible joint is treated as a pinned connection, allowing the beam to behave like a simply supported beam without transferring bending moments to the column. The participants highlight that while bolted frames allow for some flexibility, welded frames are fully rigid, impacting how bending moments are handled. Concerns are raised about the long-term integrity of laminated timber connections and the potential for elongation of bolt holes in wood. The consensus suggests that simple support connections are preferable for ensuring stability and accommodating potential movement over time.
hellophysics
[Mentor Note: This thread was spun off from an old thread here:]
https://www.physicsforums.com/threads/type-of-joints-in-portal-frame.973132/
this is probably elementary: Is it possible to decide the flexibility of a joint between gluelam beam and reinforced concrete column? if I decide it to be flexible, can it still the corner frame take bending moments? or then it behaves as a simply supported beam?
A flexible joint is a joint that is considered a pinned joint that is free to rotate the beam at that joint. Many beam to column connections are considered as pinned joints even though there may be partial rigidity in the connection. If you choose a flexible connection, the beam is designed as a simply supported beam, with no moments developed at the beam-column connection.
Likes russ_watters and berkeman
many thanks, I understand what you mean. My thought is: in steel for example, one can create frames that are bolted or welded. Welded frames are fully rigid while bolted frames allow for certain flexibility. Both allow frame action and therefore bending moments in the corners. I was wondering if between gluelam beam and reinforced concrete column one can also decide this according to the method of connecting them.
Yes, one can.
In my opinion, it is better not to transfer bending moments to any column via a horizontal member solidly attached to it, unless it is convenient for other reasons.
Welcome!
Are you referring to a portal frame type of structure?
If not, note that this is an old thread.
I recommend you to open a new one in order to get attention from a greater number of members, who can discuss details with you.
Perhaps, @berkeman can help with openining a new thread.
Thanks again. Yes, it's a portal frame structure with a timber beam and a reinforced concrete column in one of the two ends. In the other the column is in timber. That reinforced column is indeed attached to a reinforced concrete wall and both are fixed to the ground with a foundation as they are for snow avalanche protection.
As the frames I know are all from the same materials, I wanted to know if I could do one from two different materials. As the reinforced concrete wall is for avalanche protection and I would like to protect my building from a possible impact, I was considering to use a flexible connection between timber and reinforced concrete.
In any case, this is a project proposal, not a building I am building myself and without permissions. The appropriate experts will come at the right time, but I want to understand the problem to better design a solution. Thanks again for your time with the reply. I came across this old post and though you know well what you are talking about.
Laminated timber is a bit less strong than sawn timber of the same size, , but has its advantages in certain cases. Be aware of the possibility of the long term separation of the laminated layers, as i have seen this many times.
Simple support connections of wood beam to concrete columns is not a problem, using clip angles or shelf bolted to the wood and anchored into the concrete. I would be ver1y weary of a fixed wood bean to column of any material, since bolt holes in the wood tend to elongate after time and cause rotation at the ends. The simple support connection seems to meet your needs.
Likes russ_watters and Lnewqban
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
