Questions regarding equation for circular mode frequency
The discussion focuses on calculating the circular mode frequency for an open-ended pipe using the equation f = (t/(2*d^2))*SQRT(E/density). Clarification is sought on whether to multiply the values inside the square root by gravity to ensure correct units, with responses indicating that consistent SI units are necessary. The frequency f is confirmed to be in radians per second, requiring division by 2π to convert to cycles per second. Additionally, a similar frequency conversion is questioned for an equation related to transverse waves in a pipe, which is affirmed to yield frequency in hertz. Overall, the importance of unit consistency and proper frequency conversions is emphasized.
GenSoft3d
I'm trying to determine the circular mode frequency for an open-ended pipe using the following equation and could use some clarification:
f - frequency
E - modulus of elasticity
d - mean diameter
t - wall thickness
My first question is; do I need to multiply the values inside the SQRT by gravity (386.4 in/sec2) in order to get the correct units for this equation?
Also, is the frequency noted here (f) referring to radian per second and will I need to divide it by 2*pi in order to convert it to cycles per second?
Any help would be greatly appreciated. Thanks!
It has the right units as it is. The part with the square root is the speed of sound in the material of the pipe.
You need to use consistent units. SI units (kg/m^3 and Pascals) are consistent. Units that mix up "pounds mass" and "pounds force" are not.
Yes.
Thanks so much for the help on this... I really appreciate it!
I may be asking the same question twice but can you verify for me if I need to apply the same freq conversion for Hz (/2*pi) to the following equation used to determine transverse waves in a pipe with free ends?
fn=pi*vKm^2/8L^2
where:
v= √ (Y/r)
Y= Young's modulus
r= density
K= 1/2 * √ (a^2 + b^2)
a= inside radii
b= outside radii
L= length
m= 3.0112, 5, 7...(2n+1)
fn=pi*vKm^2/8L^2
where:
v= √ (Y/r)
Y= Young's modulus
r= density
a= inside radii
b= outside radii
L= length
This gives the frequency in hertz, according to Ross - Percussion instruments.
Susskind (in The Theoretical Minimum, volume 1, pages 203-205) writes the Lagrangian for the magnetic field as ##L=\frac m 2(\dot x^2+\dot y^2 + \dot z^2)+ \frac e c (\dot x A_x +\dot y A_y +\dot z A_z)## and then calculates ##\dot p_x =ma_x + \frac e c \frac d {dt} A_x=ma_x + \frac e c(\frac {\partial A_x} {\partial x}\dot x + \frac {\partial A_x} {\partial y}\dot y + \frac {\partial A_x} {\partial z}\dot z)##. I have problems with the last step. I might have written ##\frac {dA_x} {dt}...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
