- #71
name123
- 510
- 5
PeterDonis said:In other words, why couldn't the distance between the atoms that are lined up change? We can verify that that doesn't change too, by measurements. In addition to counting the atoms, we also use strain gauges to measure the inter-atomic forces, and verify that they don't change either--all of the strain gauges mounted on the sphere read the same when it is moving at 87% of the speed of light relative to the poles, as when it is at rest relative to the poles. (Or think up any other measure of density you like; the measurement, if made by apparatus at rest relative to the sphere, will be the same regardless of the sphere's speed relative to the poles.)
Well just rewinding to the conveyor belt scenario, where roughly 29,979,245.8 A-Team 1m rulers are laid out between each of the B-Team observers and then the conveyor belt is started. When it gets up to speed and they make their own 1m rulers from the same material and they find that the distance between the B-Team observers is 30,130,275.702 B-Team 1m rulers. Are you saying that the atomic density in those B team rulers are the same but they are just shorter (have less atoms)?
PeterDonis said:No. The length contraction is only in the ##x## direction. The relative motion in the ##y## direction between the sphere and the poles is too slow to have any significant length contraction effect.
It might have been traveling faster in the y than the x.
PeterDonis said:This sentence is a bit garbled, but I assume you mean "they're pretty sure something has changed even though neither of them can notice anything changing in their rest frame".
As you state it, this is false; each of them, in their own rest frame, measures the other to be length contracted, whereas if they were both at rest relative to each other they would not. So their relative motion does cause an observable change. The point is simply that there is no observable change in measurements that each one makes in their own rest frame of themselves--no measurement of the sphere in the sphere's rest frame changes, and no measurement of the poles in the poles' rest frame changes. But that doesn't mean there is no observable change anywhere.
Yes it is the observable change with relative motion that we are talking about.
Is it ok for the cartoon characters to conclude that something has changed span?
