Quick convolution integral checking
dfx
Consider a linear system with the impulse response:
g(t) = 3x^2 - 4x + 7 for t>0 and 0 otherwise.
Find the output for the input f(t) = t for t \geq 0 and f(t) = 0 for t<0.
\[ \int_{-\infty}^t f(t - \tau)g(\tau)\,d\tau\]
\[ \int_0^t f(t - \tau)g(\tau)\,d\tau\]
\[ \int_0^t (t - \tau)(3\tau^2 - 4\tau + 7\,d\tau\)]
and the answer I keep getting is
\frac{t^4}{4} - \frac{2t^3}{3} + \frac{7t^2}{2}
whereas the official given answer has the sign in the middle term as a plus: +\frac{2t^3}{3}
I've even tried wolfram and I think I'm correct:
http://img58.imageshack.us/img58/8637/mspzk2.gif (obviously with different variables - x instead of tau, but still evaluted between t and 0).
If anyone could clear up the correct answer that would be much appreciated.
...anyone?
Even I got the same answer as you. So I guess not much of a help.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
