Maintaining Submerged Objects: Understanding Density and Height
  • Thread starter Thread starter AirForceOne
To keep an object submerged at a specific height underwater, its density must be equal to that of the water for neutral buoyancy, meaning it neither floats nor sinks. If the object's density is lower, it will float; if higher, it will sink. However, real bodies of water have varying densities and currents that can affect the object's position, complicating the maintenance of neutral buoyancy. A practical approach is to design the object to be slightly buoyant and anchor it to the bottom to maintain the desired depth. This method accounts for the dynamic nature of water environments.
AirForceOne
How do you keep a simple object submerged underwater at a certain height from the surface of the water? What would its density have to be? I'm guessing it's very close to the density of water.
Sorry if that was a very basic/dumb question...
If the object's density is equal to the water's density then it will have neutral buoyancy, which means it won't float or sink, rather it will stay where you put it. If it's any less it will float and any more and it will sink. With water of a constant uniform density you won't be able to make an object that will sink to a certain depth then stay there.
In practice though, actual bodies of water will have slightly varying densities, both with time and depth. In addition, there will be upward and downward currents that will move an object that even if it is equal in density to the surrounding water. This will make it difficult to build anything that is constantly neutrally buoyant. A more practical solution may be to simply make the object slightly buoyant and then anchor it to something on the bottom to keep it the certain distance from the surface.
This answered my question perfectly. Thank you.
I'm not a student or graduate in Astrophysics.. Wish i were though... I was playing with distances between planets... I found that Mars, Ceres, Jupiter and Saturn have somthing in common... They are in a kind of ratio with another.. They all got a difference about 1,84 to 1,88x the distance from the previous planet, sub-planet. On average 1,845x. I thought this can be coincidential. So i took the big moons of Jupiter and Saturn to do the same thing jupiter; Io, Europa and Ganymede have a...
9K
  • · Replies 16 ·
11K
  • · Replies 25 ·
