Quick Help Dividing Polynomials
  • Thread starter Thread starter marcflores
    Polynomials
The discussion focuses on the polynomial division of (6x^4-3x^2+x-4) by (2x^2+1). The participant seeks clarification on whether it is acceptable to rearrange the terms of the dividend using the commutative law of addition. Responses emphasize the importance of maintaining the order of terms in decreasing power to avoid confusion during the division process. It is noted that while rearranging is permissible, it should be done carefully to ensure accuracy in calculations. The final answer provided is confirmed as correct, highlighting the need for clarity in polynomial division steps.
marcflores
(6x^4-3x^2+x-4) / (2x^2+1)
Relevant equations?
Here is my attempt, but I want to make sure that I didn't break any laws by changing the number to be divided by switching the last two terms around by using the commutative law of addition:
[6x^4-3x^2+(-4)+x] -- is this okay so far?
So, I wrote 2x^2+1 divided by [6x^4-3x^2+(-4)+x]
Then I wrote it out like long division (can't find the division symbol in laTex) and here are the steps I took:
(3x^2)(2x^2+1) = 6x^4+3x^2
Then, I subtracted the product from the first two terms of the dividend:
(6x^4-3x^2) - (6x^4+3x^2) = -6x^2
Carry down the +(-4) from the dividend and I have:
-6x^2-4
Then I multiply the divisor by negative three and subtract the product from -6x^2-4:
(2x^2+1)(-3) = -6x^2-3
That leaves me with -1 and I carry down the x from the dividend leaving:
-1 + x
So, my answer is 3x^2-3+\frac{-1+x}{2x^2+1}
I just want to know if this is correct or if I was wrong in redistributing the terms in the original dividend. Thanks.
Jeez, re-reading my post even left me confused. It's too bad I can't replicate it on the forums as I have it written on my paper.
your final answer is right.
Usually you want to keep the terms in decreasing power so you know for sure you do them in that order. you don't want to do 3x^2 before doing 6x^4 here.
You can change the terms around just be sure to do them in the right order otherwise you could get mixed up and get the answer wrong.
I'll keep that in mind. Thanks for the input and help.
I think the reason I did 3x^2 was to find a monomial that would produce the product 6x^4 when multiplied by 2x^2 (the first term in the divisor).
