Quick question, phasors and impedance
The discussion clarifies that the minus sign in the angle of the current phasor is removed because it represents the complex conjugate, denoted as I*. This change in sign occurs when using the formula S = VI*, where S is the complex power. The factor of 0.5 is included when using peak values of voltage and current. Participants emphasize understanding the notation and the importance of recognizing the complex conjugate in phasor calculations. Mastery of these concepts is essential for accurate application in electrical engineering.
clurt
Please see attached
On line S=0.5*V*I why is the minus sign removed from in front of the "I" angle. 25.38 specifically. Could is be a typo?
http://imgur.com/eUmEovo
It's not a typo. ##I## is complex conjugated, hence the star ##I^*##. When you complex conjugate a phasor, you change the sign of the angle.
Do you always flip the minus sign when when using S=VI? And what about the half in front, all the time too?
Half in the front when you use peak values of V and I
if the formula is $$S = \frac{1}{2} \cdot V_s \cdot I^*_s $$ so you take ##I_s^*## which is the complex conjugate of ##I_s##. Since it's written in a modulus and phase format, you just have to invert the sign of the phase of ##I## to obtain it (draw both numbers in the complex plane and it's evident that the modulus stays the same but the phase changes).
I don't think you should memorize rules of flipping that sign or not, just read the formula (it's S = VI*, not S = VI). If you weren't able to see why the minus sign changed given the formula, then you either don't know the notation used here for the complex conjugate (in mathematics classes I've usually seen it written as ##\overline{I}##, but it's written the other way in engineering) or you need to study complex numbers.
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
