Rack and Pinion Design Question
  • Thread starter Thread starter Jhoneine
    Design
The discussion focuses on translating vertical rack movement into rotary motion using footstep force. To determine the rack's linear velocity, one can apply Newton's law (F=ma) to calculate acceleration based on the net force and mass involved. An alternative approach involves using the work-energy principle, where work equals force multiplied by displacement. A spring release mechanism could facilitate movement, allowing for incremental gear shifts with each step. Ultimately, linear velocity can be derived from rotational velocity using the formula V = angular velocity times radius.
Jhoneine
Hi, I am planning on translating a vertical rack movement to a pinion rotary motion by a human footstep force. Any idea on how to obtain the rack linear velocity theoretically ?
Sorry but I can't immediately see what there is to work out ?
Please explain what you are trying to do more completely and then you will probably get a more helpful answer .
Sounds like he's trying to work out the power that can be harvested from a man walking over a foot plate in the floor.
The rack will accelerate downwards when the man steps on the foot pad. The acceleration could be calculated using Newtons law F=ma (eg using the net force on the rack/man and the mass of the combination). From that you can calculate/estimate the peak velocity after some time t (which depends on how long he stands on the footpad.
Perhaps it would be easier using work = force * displacement
If speed is not an issue, per say, you could have it attached to a spring release gear mechanism. Think of a clock gearbox. You step, the plate pushes down a lever that knocks a gear a little bit, this then returns and bypasses moving the gear. Each step moves it farther and farther. Remember, in theory, even if you have it barely move the gear, you can have that gear run against a much smaller gear attached to a larger gear. Your speed has no limit.
Your linear velocity will be easily calculated given you know the rotational velocity and the radius with the equation V = (angular velocity) times radius.
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
