Radial and tangential velocities for Inviscid flow (fluid mechanics)
In fluid mechanics, when analyzing flow past a cylinder, the radial velocity component must be zero at the surface because flow cannot penetrate the solid surface. However, the tangential velocity component does not need to be zero at the surface in inviscid flow conditions. Stagnation points, located at the leading and trailing edges of the cylinder, exhibit both radial and tangential velocities of zero. Understanding these conditions is crucial for solving problems involving stream-functions and velocity components. This clarification enhances the comprehension of flow behavior around cylindrical objects.
wahaj
After I have an expression for the stream-function in a problem, I can differentiate to get the tangential and radial velocities because I need those to solve the problem. But I don't understand when the tangential velocity will be 0 and when the radial is 0. Can some on explain?
Is this for flow past a cylinder or past a sphere?
Chet
I didn't realize there was a difference but cylinders for this question.
If you're referring to the radial and tangential velocity components at the surface of the cylinder, then the radial component has to be zero, since you can't have flow through the solid surface of the cylinder. For inviscid flow, the tangential component of the velocity does not have to be zero at a solid surface. The leading edge and the trailing edge of the cylinder are both stagnation points, so both components of velocity are zero at these points.
Chet
Thanks for clearing this up.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
I know that mass does not affect the acceleration in a simple pendulum undergoing SHM, but how does the mass on the spring that makes up the elastic pendulum affect its acceleration? Certainly, there must be a change due to the displacement from equilibrium caused by each differing mass? I am talking about finding the acceleration at a specific time on each trial with different masses and comparing them. How would they compare and why?
