MHB Radian Measure: Show Cone Surface Area is $\pi rl$
  • Thread starter Thread starter Sherlock16
    Cone Measure
A cone's curved surface area can be derived by transforming it into a sector of a circle with radius equal to the slant height, \( l \), and angle \( \theta \). The relationship between the arc length of the sector and the circumference of the cone's base leads to the equation \( l\theta = 2\pi r \). By calculating the area of the sector, which is given by \( \frac{1}{2}l^2\theta \), and substituting for \( \theta \), it can be shown that the curved surface area of the cone is \( \pi rl \). This derivation highlights the connection between the geometry of the cone and the properties of circular sectors. Understanding this relationship is crucial for solving problems involving cone surface areas.
Sherlock16
A cone with base radius $r$, vertical height $h$ and slant height $l$ has its curved surface slit and flattened out into a sector with radius $l$ and angle $\theta$. By comparing the arc length of this sector with the circumference of the base of the cone, show that $l\theta = 2\pi r$, and deduce by calculating the area of the sector, that the curved surface area of the cone is $\pi rl$.
Mathematics news on Phys.org
Welcome, Sherlock16!
Please show what you've tried or what your thoughts are on this problem, so that we could better assist you.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
