Radiation pressure and electromagnetic waves
The discussion focuses on calculating the height of a perfectly reflecting cylinder levitated by a laser beam's radiation pressure. The forces acting on the cylinder, including the upward radiation force and the downward gravitational force, are set equal to each other to find the height. The radiation force is expressed as F = 2IA/c, while the gravitational force is represented as F = mg, with mass derived from the cylinder's volume and density. The participant correctly identifies the need to adjust the area calculations to reflect only the cross-sectional area of the cylinder facing the beam. Ultimately, the height is derived as H = 8P/(cπD²gρ), demonstrating the relationship between the laser power, cylinder dimensions, and gravitational effects.
jdismu1
A laser beam of power P and diameter D is directed upward at one circular face (of diameter d < D) of a perfectly reflecting cylinder. The cylinder is levitated because the upward radiation force matches the downward gravitational force. If the cylinder's density is ρ, what is its height H? State your answer in terms of the given variables, using c and g if needed.
http://edugen.wiley.com/edugen/courses/crs4957/art/qb/qu/c33/q26.jpg
Intensity = P/A
F = 2IA/c <-- for totally reflecting surface
\rho = m/V
F(gravity) = mg
i set the two forces equal to each other because the cylinder is floating.
F(due to beam)=F(gravity)
F(due to beam) = 2IA/c
F(gravity)=mg
F(gravity)=\pi*r^2*h*\rho)*g <-substituted density (constant rho) and volume (\pi*r^2*h) for mass
**i think this is where i may be going wrong**
F(due to beam)= 2IA/c = 2P/c <-- substituted in the equation of intensity where I = P/A, power divided by area.
after this i solved for H and got, i also substituted r = d/2 because r was not a variable to use in this problem
2P/(\pi*(d/2)^2*h*\rho*g*c) = H
Figured it out
first change the equations to eliminate all variables that are not used in the problem.
Fr = 2IAdisk/c <-- area in this equation is only concerned with the area of the disk that is reflecting the beam, not the total area of the beam
intensity was not given as a known value so we have to change it to appropriate variables
I = P/Abeam <-- this is where i was wrong, the area in this equation is with respect to the beam as a whole and is only concerned with the cross sectional area at the bottom of the cylinder
Abeam = (pi)*r2
because r was not given as one of the appropriate variable i had to change it to D
so now we have
Abeam = (pi)*D2/4 <-- (D/2)2 = D2/4
plugging the new value of I into the equation you get
Fr = 8AdiskP/[c*(pi)*D2] <-- bring the 4 up to the top and combine it with 2 to get 8 XD
next for Fg=mg, m is not given as a know value so we have to change it to things that we know
m = V(rho) <-- rho is density here
volume is also not given so we have to change it yet again
V = (pi)*r2*h <-- for convenience ill use (pi)*r2*h = Adisk*h
now we have a value for m that we can use
m = Adisk*h*(rho)
finally Fg = mg
Fg = Adisk*h*(rho)*g
set the two equation equal to each other because forces are balance and the cylinder is floating in air
Fr=Fg
plug in know values for the forces
8AdiskP/[c*(pi)*D2]=Adisk*h*(rho)*g
Areas of the disk cancel and bring everything else except for H over to the other side and the answer is
h = 8P/[c*(pi)*D2*g*(rho)]
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
