Radiation Rate of 0.1m Cube Metal at 200C
To calculate the radiation rate of a 0.1m cube of metal with an emissivity of 0.75 at 200°C, the formula H=AeσT^4 is used, where σ is the Stefan-Boltzmann constant. The area of one face of the cube is 0.01 m², and since a cube has six faces, the total area is 0.06 m². Converting 200°C to Kelvin gives 473K, and substituting these values into the formula results in a radiation rate of 128W, correcting the initial miscalculation of 21.28W. Proper unit conversion and consideration of the cube's total surface area are crucial for accurate results.
Kyle North
At what rate does a 0.1m cube of metal with emissivity e=0.75 radiate energy if it is at a temperature of 200C?
H=AeσT^4, σ=5.67 x10^-8
I found the area of the cute to be A=(0.1m)^2=0.01m, and the turned 200C into 473K, but when I type them all in I get 21.28W and the answer is 128W?
How many faces does a cube have?
6.. thanks!
Also, (0.1 m)2 = 0.01 m2 Don't forget to square the units.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
