Radioactive Nuclear Polonium Battery Question
The discussion revolves around calculating the power output of a nuclear battery using polonium-210, specifically focusing on two main questions regarding initial power output and power after one year. Participants express frustration over being directed to search for values online, feeling that the assignment's weight is disproportionate to the guidance provided. The suggested method involves using kinetic energy calculations and the half-life of polonium-210 to determine activity and remaining nucleons over time. Clarifications indicate that direct alpha emission energies can simplify the calculations without needing to derive them from kinetic energy equations. Overall, the conversation highlights the challenges of finding reliable data for complex nuclear physics problems.
elliottmarter
Question
The α-emitter 210, 84 Po is used in a nuclear battery. The kinetic energy of the emitted alpha particles can be worked out from energy and momentum conservation. It is converted into electrical energy at 5.0% efficiency.
(a) Determine the initial power output (in W) of the battery if it contains 320 g of 210, 84 Po. Look "www.google.com/search?hl=en&q=210+Po+nuclear+decay"[/URL] (for instance) for relevant data.
(b) Determine the power output (in W) of the battery in (a) after 1 year of operation.
[RIGHT][8 marks][/RIGHT]
[U][B]Answer[/B][/U]
not sure if anyone agrees with me on this one, but this work is worth 40% of the entire module and they have the cheek to link me to a google search and effectively tell me to find all the necessary values myself, i wasn't impressed...especially when you think that you might have the knowledge to do the question and just not know where to find reliable values from...
anyway on with my answer
(a) well i would firstly use [B]kinetic energy = 1/2 mv[SUP]2[/SUP][/B] where m=mass of an alpha particle and v=emission speed then times that by amount emitted per second (activity) to get an answer in joules per second (ie Watts) then times by 0.05 for an efficiency factor of 5%
(b) find the half life of 210, 84 Po and use [B]N = N[SUB]0[/SUB] e[SUP]-[tex]\lambda[/tex] t[/SUP][/B] to find the number of nucleons left after one year then use [B]R=[tex]\lambda[/tex] N[/B] for the activity after one year, then simply repeat the method for question (a)...
i appreciate that these might be the right methods but i posted this in order to give you an idea of what values I'm searching for, if I am wrong in the solutions above please say.
any feedback would be much appreciated, thanks guys
Everything you said looks correct to me. Probably when you look up the alpha emission of Po-210, you will find the alpha emission energies directly, so you won't need to use E=1/2 mv^2.
Thanks for the reply phyzguy i was thinking i needed loads of extra info but now i realize the only bit of information about Po 210 that I could find online would be its half life as the activity and decay constant etc etc etc depend on how much of the stuff is left in this case 320g
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
