Radius of convergence quick help
SoulofLoneWlf
quick help on this i seem to be missing some logic or process
determine the lower bound the radius of convergence of series solutions about the given X0
(2+x^2)y''-xy'+4y=0
xo=0
Well, we can't really help you unless you start the process. Do you have any idea where to go from here?
EDIT: If you've got absolutely no idea where to start, you should just Google "radius of convergence series solutions."
well i was seeing that (2+x^2) has no discontinuity
so shouldn't the radius be infinity?
What does discontinuities of P(x) have to do with anything? A hint would be writing the DE in the form y^{''}+P(x)y^{'}+Q(x)y=0 and using a Fuchs' Theorem.
thanks guys just hammered through it think i got my head around it :)
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
