Raman Spectroscopy Setup Not Functioning as Intended
An attempt is being made to revive an old Raman spectrometer, utilizing a functioning probe head, laser system, and a new CCD spectrometer, but no usable signals are being obtained. The system is set up with a 785nm laser, a Thorlabs CCD175 spectrometer, and a Thorlabs FELH0800 edgepass filter. Despite varying exposure times and laser power, only noise is detected, and calibration lights yield no signal. Troubleshooting steps include removing the filter, which allows detection of laser light but no Raman signal, and observing that white light can pass through without the filter. Suggestions are sought for further diagnostics to identify the failure point in the system.
Bogthornder
TL;DR Summary
I am attempting to reuse components of an old Raman spectrometer, and cannot obtain any signals.
I am attempting to revive an old Raman spectrometer that had a few components stop working. I was left with a functioning probe head, laser system, and some optical components. Currently, I have purchased a new CCD spectrometer and a few optical components to replace those that were specific to the old CCD. Now that I have the entire set-up assembled, I am not able to obtain any sort of spectra, or any signal at all. The only signal I can obtain is noise, and even when using calibration lights there is no signal obtained. More specifications about the system are below:
Laser: Adjustable with a maximum power of 400 mW, 785nm wavelength.
Probehead: Constructed by Kaiser Optical (now defunct)
Spectrometer: ThorLabs CCD175
Laser Filter: Thorlabs FELH0800 Edgepass Filter (Cut on wavelength is 800nm)
Components are arranged in the following fashion:
Laser > Fiber optic > Probe head > Sample > Probe head > Fiber optic > Free space coupling mount > Laser Filter > Fiber optic > CCD
I have attempted to vary the exposure times, change the laser power, and use software for spectral analysis to retrieve any information, but it appears that the set-up is not actually producing any usable signals. The sample I am using to test the set-up is a polystyrene standard. Some additional steps I’ve taken in troubleshooting:
  • Removing the filter from the path to ensure that the path functions as expected. When the filter was removed, light can be detected by the CCD however it is only the laser light and there appears to be no Raman signal despite the probe head’s internal filtering.
  • When a white light is shone into the probe head without the filter, light can be detected including light above the 800nm cut on. However when the filter is added this light disappears. Using this light source with the filter along, there is infrared light being transmitted through the filter that can be seen with a camera.
Does anyone have any suggestions for parameters that can be tested to determine where the system is failing to work? I am happy to provide any additional information that could be useful in the diagnostics.
Chemistry news on Phys.org
Bogthornder said:
TL;DR Summary: I am attempting to reuse components of an old Raman spectrometer, and cannot obtain any signals.
I'm probably not of much help but I'm curious as to whether you have drawings or diagrams of this setup of yours that you'd be willing to share?
Of course! I don't know why I didn't think to attach it before.
I don't have a lot of information concerning the probe head. I know it is a Kaiser Optical Systems Inc. Mk. II, but the documentation I have doesn't seem to contain any optical diagrams that I can find, but I thought I might attach an image of the internals in case anyone other than me can see something obvious.
Yeah, as I suspected it's beyond me. The reason I'm interested at all is because I wanted to realize a Raman mass spec using 3D printed parts. I started a thread along those lines here:
Apropos Raspberry PI DIY Mass Spec using Raman Scattering
Well, if nothing else I got your thread bumped. :smile:
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
