Range of a function, very simple & basic question
  • Thread starter Thread starter sachin_naik04
    Function Range
The discussion focuses on finding the range of two quadratic functions within specified intervals. For the first function, f(x) = 3x² + 4, the range is determined to be 4 ≤ f(x) ≤ 52 by following a systematic approach. The second function, f(x) = 9 - 2x², initially causes confusion, but it is clarified that the steps taken to find the range are correct, specifically regarding squaring the bounds and reversing inequalities when multiplying by negative numbers. The final steps involve adding constants to complete the range calculation. The conversation emphasizes the importance of following each step carefully to achieve the correct answer.
sachin_naik04
Just go through the following problem
Question 1:find the range of the following function
f(x)=3x2+4 for -4≤x≤3
Answer:
rewriting -4≤x≤3
step1. 0≤x2≤16
step2. multiply 3 for the entire step 1.
step4. add 4 for the entire step1.
step5. 4≤f(x)≤52
so the above problem i have understood
now how do i solve the following problem using the same method as above, because the following problem is a bit different from the first one, and i get a reverse answer
Question 2: find the range of the following function
f(x)=9-2x2 for -3≤x≤3
rewriting -3≤x≤3
step 1. 0≤x2≤9 now is this step correct?, i don't think so.
step 2. ?
step 3. ?
step 4. ?
please note: i cannot find the range directly because each step carries marks
Mathematics news on Phys.org
The step is correct. .
if you square x<=3 that will give you (x^2 <=9) or (x<0)
if you square x>=-3 that will give you ((x^2 <= 9) or (x>0))
if both are true you just get (x^2 <= 9)
Answer:
rewriting -4≤x≤3
step1. 0≤x2≤16
step5. 4≤f(x)≤52
rewriting -3≤x≤3
Yes, it is correct. Why would you not think so?
step 2. ?
Multiplying each part of the inequality by negative 2 reverses the inequality:
-18\le x^2\le 0
Since you say you got a "reverse answer" that may have been your mistake.
step 3. ?
Add 9 to each part.
step 4. ?
Write down your answer!
@HallsofIvy
oh thanks a lot, that helped me
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
