Ranking the force of point charges
To rank the forces exerted on the point charges by the insulating spherical shell, apply Coulomb's law to each charge using the formula F = K(q1)(q2)/r^2. The distance r should be measured from the center of the sphere to each charge. Substitute the values for each charge's magnitude and distance into the equation to calculate the force for each. After calculating, compare the magnitudes of the forces to determine their ranking. Understanding Gauss's Law may provide additional insights, but it is not necessary for this problem.
macaco
5 point charges;
q1; charge = +q distance = d
q2; charge = +2q distance = 3d
q3; charge = -3q distance = 2d
q4; charge = -4q distance = 3d
q5; charge = -5q distance = 2d
are placed in the vicinity of an insulating spherical shell with a charge (+Q), distributed uniformly over its surface.
Rank the point charges in order of the increasing magnitude of force exerted on them by the sphere. Indicate all ties where appropriate. Show all calculations of force.
(there is a diagram attached, but I don't have a scanner and my teacher siad it is only to visualise the problem.)
Coulomb's law;
F= K (q1)(q2)
r squared
My teacher said to apply coulombs law to each of the charges, than compare each.
I tried this, but have no idea of what values I should use for q1 and which I should use for q2.
And do I need the distance of each charge from the edge of the sphere?
The more I look at it, the less sense it makes.
You see that F = qE and F = kq1q2/r^2. From Gauss's Law the total charge enclosed is Q. You are still taking r as being the distance from the center of the sphere to the point charge. Simply make q1 = Q and substitute the different q2 values and r values and compare those magnitudes. If you haven't seen Gauss's Law this will probably make more sense when you do.
No, we haven't touched on Gauss's law yet.
I'm still not sure how to rank the equations after I've substituted the values.
so far I have;
q1=> F= K Qq
d^2
q2=> F= K 2Qq
3d^2
q3=> F= K -3Qq
4d^2
q4=> F= K -4Qq
9d^2
q5=> F= K -5Qq
4d^2
how would I rank these?
Or is there more I need to do first?
i hope those equations still make sense;
it deleted the spaces in the bottom row.
The first one should be;
F=
K Qq
d^2
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
