Raspberry Pi 4 / Debian : Static IP on one SSID and Dynamic on another
The Raspberry Pi 4's GUI widget for configuring WLAN settings on a per-SSID basis is malfunctioning, causing all SSIDs to adopt the same settings. While some sources suggest modifying the dhcpd.conf file to set static IP parameters for specific SSIDs, there is uncertainty about how to configure dynamic IPs alongside static ones for the same interface. It is noted that the dhcpd.conf file is primarily for static IP assignments, and mixing static and dynamic IPs on a network typically involves assigning static IPs to devices like printers for consistent accessibility. Further investigation is needed to clarify the process for achieving a mixed IP configuration on a per-SSID basis.
Swamp Thing
Insights Author
My Raspberry Pi 4 has a GUI widget that is supposed to let us specify WLAN settings on a per-SSID basis, but it doesn't work. (All SSIDs end up with the same setting).
Some articles on the net say that one can modify the dhcpd.conf file with an entry headed by the SSID name and then put in static IP parameters in that section. But I couldn't find how to specify a dynamic IP for a given SSID on the same interface (and to mix static and dynamic on a per-SSID basis for a given WLAN).
How can this be done?
Computer science news on Phys.org
I don't think you can dynamically allocate by altering the dhcp.conf file. It is for the static IP's only. When I did my cluster, I had to put static IP's so that everyone could see each other, and my POE swtich assigned IP's.
As for mixing static and dynamics on a network, I'd have to investigate a little. Usually statics are given to printers etc so everyone can see them all the time.
Let me cogitate a little and get back to you.
Well, the date has now passed, and Windows 10 is no longer supported. Hopefully, the readers of this forum have done one of the many ways this issue can be handled. If not, do a YouTube search and a smorgasbord of solutions will be returned. What I want to mention is that I chose to use a debloated Windows from a debloater. There are many available options, e.g., Chris Titus Utilities (I used a product called Velotic, which also features AI to prevent your computer from overheating etc...
