- 30,133
- 7,398
- TL;DR Summary
- Effect of the position of an insulating layer on cooling and heating
I am contemplating installing external insulation on your hundred year old fashioned house with solid walls. This house and those of my neighbours are described as 'cold houses' by the neighbours. I need to do something if I can and eternal insulation is a possible solution.
I'm trying to predict the likely improvement of some external cladding vs a cavity wall. the usual calculation used in planning CH systems. The U values of the sort of insulation I could use is in the right order of the U value improvement going from solid to cavity walls. (a number of tables online) But the thermal capacity of the bricks must be relevant to the timescale of following the outside temperature. It's the equivalent of a chain of resistors with capacitors at the nodes. The long - term steady state will just follow a K2 law and I realise it will be swings and roundabouts, with the thermal capacity dictating the 'feel' of the walls over the short term. style.
I could spend / waste a lot of time re-inventing this wheel. Are any PF members familiar with the problem and is there a method, well known to the world with the right units and values for domestic walls
