Ratio of the velocities of two atoms, based on kinetic energy
The discussion centers on calculating the ratio of velocities between a helium atom and an oxygen atom, given that they possess the same kinetic energy. The oxygen atom is four times more massive than the helium atom. By applying the kinetic energy equation, the user rearranges the terms to isolate the velocity ratio. The final calculation shows that the ratio of the speeds is vHe/vO = 2, indicating that the helium atom moves twice as fast as the oxygen atom. This conclusion is reached through basic algebraic manipulation of the kinetic energy formula.
buttermellow
An oxygen atom is four times as massive as a helium atom. In an experiment, a helium atom and an oxygen atom have the same kinetic energy. What is the ratio vHe /vO of their speeds?
K=.5mv2
.5mHe(vHe)2=.5(4mHe)(vO)2
I'm not sure what to do with that though, how to solve for the ratio.
Have you learned basic algebraic manipulation? You just have to rearrange the equation so as to get the ratio V(he)/V(o) on one side. eg. 5a = 3b, a/b = ?
Oh my, I was making that much harder than it needed to be.
What I got:
.5mHe(vHe)2=2mHe(vO)2
mHe cancels to give (vHe)2=4(vO)2
(vHe)2/(vO)2=4
vHe/vO=\sqrt{}4=2
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
