Ray's question at Yahoo Answers regarding polynomial division
In summary, we can find the remainder R when p(x) is divided by (x-1) and (x+3) by using either the division algorithm or an alternate approach involving the definition of Q(x). The remainder is always equal to -\frac{9}{4}x-\frac{19}{4}.
MarkFL
MHB
13,288
Here is the question:
Find R ,If R when p(x) is divided by..?
If R when p(x) is divided by (x-1) is -7 and R when p(x) is divided by (x+3) is 2,
find R when p(x) is divided by (x-1) and (x+3)..
I have posted a link there to this topic so the OP can see my work.
Mathematics news on Phys.org
Hello Ray,
I will show you two methods to solve this problem.
i) By the division algorithm, we may state:
\(\displaystyle P(x)=(x-1)(x+3)Q(x)+R(x)\)
We know the degree of the remainder must be at most one less than the divisor, and so we may state:
(1) \(\displaystyle P(x)=(x-1)(x+3)Q(x)+ax+b\)
And from the remainder theorem we know:
\(\displaystyle P(1)=-7\)
\(\displaystyle P(-3)=2\)
Using these data points with (1), we obtain:
\(\displaystyle P(1)=a+b=-7\)
\(\displaystyle P(-3)=-3a+b=2\)
Subtracting the second equation from the first, we eliminate $b$ and obtain:
\(\displaystyle 4a=-9\)
\(\displaystyle a=-\frac{9}{4}\)
Substituting for $a$ into the first equation, we find:
\(\displaystyle -\frac{9}{4}+b=-7\)
\(\displaystyle b=-\frac{19}{4}\)
And so we find the remainder is:
\(\displaystyle R(x)=-\frac{9}{4}x-\frac{19}{4}\)
ii) Here's an alternate approach:
\(\displaystyle \frac{P(x)}{x-1}=Q_2(x)+\frac{-7}{x-1}\)
\(\displaystyle \frac{P(x)}{x+3}=Q_1(x)+\frac{2}{x+3}\)
Subtract the second equation from the first:
\(\displaystyle P(x)\left(\frac{1}{x-1}-\frac{1}{x+3} \right)=\left(Q_2(x)-Q_1(x) \right)+\left(\frac{-7}{x-1}-\frac{2}{x+3} \right)\)
Simplifying by combining terms, and using the definition:
\(\displaystyle 4Q(x)\equiv Q_2(x)-Q_1(x)\)
we have:
\(\displaystyle \frac{4P(x)}{(x-1)(x+3)}=4Q(x)+\frac{-9x-19}{(x-1)(x+3)}\)
Dividing through by $4$, we obtain:
\(\displaystyle \frac{P(x)}{(x-1)(x+3)}=Q(x)+\frac{-\dfrac{9}{4}x-\dfrac{19}{4}}{(x-1)(x+3)}\)
FAQ: Ray's question at Yahoo Answers regarding polynomial division
What is polynomial division?
Polynomial division is a method for dividing polynomials, which are algebraic expressions made up of variables and coefficients. It is similar to long division in arithmetic, but instead of using numbers, it involves dividing expressions with variables.
How do you perform polynomial division?
To perform polynomial division, you first arrange the terms of the dividend (the polynomial being divided) and the divisor (the polynomial doing the dividing) in descending order of exponents. Then, you divide the first term of the dividend by the first term of the divisor, and multiply the result by the divisor. This gives you the first term of the quotient. You then subtract this term from the dividend and bring down the next term. This process is repeated until all terms have been divided.
What is the remainder in polynomial division?
The remainder in polynomial division is the term that is left over after the division process is complete. It is the result of dividing a polynomial that does not divide evenly by the divisor. The remainder is typically written as a fraction with the divisor as the denominator.
What is the purpose of polynomial division?
The purpose of polynomial division is to simplify or solve polynomial expressions. It is useful in various mathematical applications, such as finding roots of polynomials, graphing curves, and solving equations. It also helps in factoring polynomials, which involves breaking them down into simpler expressions.
Are there any shortcuts for polynomial division?
Yes, there are a few shortcuts for polynomial division, such as using synthetic division for certain types of polynomials, or using the remainder theorem or the factor theorem to determine remainders without actually performing the division. However, these methods are only applicable in specific cases and may not always work. Therefore, it is important to understand the process of polynomial division in order to accurately solve polynomial problems.
