Reaction between mgso4 +k2co3?
  • MHB
  • Thread starter markosheehan
  • Tags
    Reaction
In summary, we have a question from 1989 about a chemical reaction. The conversation discusses the colors and precipitates observed in the reaction, and determines that the precipitate must be $\ce{MgCO3}$ based on the solubility of K and Mg. The conversation also mentions the general rule that metals in group 1 are more soluble than those in group 2.
markosheehan
136
can someone help me with the 1989 question.
i think part i is k2(c03)
for ii the gas given of is co2. 1 one the precipitates given off was caco3. i am not sure what the other was. is it supposed to be a reaction between mgso4 +k2co3?
Mathematics news on Phys.org
Hi markosheehan,
Indeed, the lilac color indicates we have K.
And the white precipitate of the colorless gas in lime water suggests CO2.
So X is probably $\ce{K2CO3}$.
And yes, when combining a solution of $\ce{K2CO3}$ with a solution of $\ce{MgSO4}$, we have:
$$\ce{2K+ + CO3^{2-} + Mg^{2+} + SO4^{2-}}$$
Since K is very soluble, the precipitate must be from Mg.
And since we can assume that it won't be the original magnesium sulfate, which was dissolved after all, that leaves us with only one choice.
It should be $\ce{MgCO3}$, which is white, confirming our analysis.
thanks for your help
how did you know "Since K is very soluble, the precipitate must be from Mg."
is it just a general rule you just learn off that potassium is more soluble than mg. just because k is more soluble than mg how did you know mg would join with the (co3)^2-
thanks
thanks
Potassium is in group 1, meaning it has a single electron in its outer shell that it is eager to release, becoming an ion that is dissolved in water.
This holds true for all metals in group 1 (Li, K, Na).
So we can expect Mg (group 2) to be less soluble than K.
This is a general rule -- chemical intuition if you will.
That means that Mg must join with either CO3 or with SO4.
Since it was already dissolved with SO4, the obvious candidate is CO3.
thanks
FAQ: Reaction between mgso4 +k2co3?
What is the chemical equation for the reaction between MgSO4 and K2CO3?
The chemical equation for this reaction is MgSO4 + K2CO3 → MgCO3 + K2SO4.
What type of reaction is the reaction between MgSO4 and K2CO3?
This is a double displacement reaction, also known as a metathesis reaction, where the cations and anions of two compounds switch places to form two new compounds.
What are the products of the reaction between MgSO4 and K2CO3?
The products of this reaction are MgCO3 and K2SO4.
What are the physical states of the reactants and products in the reaction between MgSO4 and K2CO3?
MgSO4 is a solid, while K2CO3 is also a solid. The products, MgCO3 and K2SO4, are both solids as well.
What is the purpose of using MgSO4 and K2CO3 in a reaction?
MgSO4 and K2CO3 are often used as reactants in laboratory experiments to produce other compounds or to study the properties of different substances. They can also be used in industrial processes, such as in the production of fertilizers or as a source of magnesium for plant growth.
