Chemistry Reactions With Dilute Hydrochloric Acid
The discussion focuses on the reactions of sodium bromide (NaBr) and lead(II) nitrate (Pb(NO3)2) with dilute hydrochloric acid (HCl). It is noted that NaBr reacts with HCl to produce sodium chloride (NaCl) and hydrogen bromide (HBr), though the formation of HBr gas is questioned due to its density. The participant expresses confusion about the accuracy of their reaction predictions and seeks clarification on the expected outcomes with dilute acid. It is concluded that reactions with dilute HCl would not produce HBr gas, and any HBr generated from concentrated HCl would likely be contaminated. Reliable sources for these reactions are reportedly difficult to find.
A13235378
In one of the exercises on inorganic reactions in my test, it consisted of marking the alternative in which a solid substance at 25 degrees Celsius reacted with diluted HCl and formed a gas denser than atmospheric air.
HCl + NaBr = NaCl + HBr
One of the alternatives was NaBr
My resolution was as follows:
NaBr + HCl forms NaCl and HBr
I researched and saw that HBr would be a gas and would be denser than air because its molar mass is greater.
However, the answer was not that.
My error is in which step?
In the reaction? What would be correct?
Furthermore, the other alternative presents the substance Pb(NO3)2
Reaction with HCl would form PbCl2 and HNO3, not forming gas.
Is my thinking correct?
I can't find reliable sources with these reactions made.
Thanks for the help.
Problem is with the reaction and the _diluted_ acid.
And how would the reaction be with the diluted acid?
There would be none.
Some quantities of HBr can be probably produced with concentrated HCl, but even that is not listed as a viable way of lab synthesis. It will be probably way too contaminated with just HCl.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
