Reading current through a capacitor
In experiments involving Langmuir probes in plasma, the probes function similarly to capacitors for measuring current density. An ammeter can be used directly without an additional resistor, as it has internal resistors for current measurement. However, when interfacing with a data acquisition system (DAQ), a resistor is necessary to measure current, as the DAQ is configured for potential measurements. The resistor should be placed in series with the probes to accurately reflect the current readings. The discussion highlights the importance of understanding the configuration for effective current measurement in plasma experiments.
limofunder
I am working on an experiment involving Langmuir probes. I believe the probes act as capacitors when placed in a plasma to get a reading of the current density in the plasma. However, since we are biasing a voltage, I know that in order to read the current we must insert a resistor between the probes and the ammeter. How should this resistor be placed, in series or in parallel?
You don't need a resistor if you are using an ammeter. The only time is you need a resistor in series is if you want to use a VOLTMETER to read a current (in which case you get the current from I=U/R).
But maybe I missunderstood the question? There could be other reasons for putting a resistor in series (e.g. current limiting) but that has nothing to do with the ammeter.
Yes, I apologize, I understand the ammeter already has internal resistors to measure the current. I plan to run this through a DAQ which requires a resistor to measure the current sent to the computer (the program I'm using asks for a resistance value since the DAQs are configured to measure potential), and I wasn't sure if I should have the resistor in series with or parallel to the probes.
Totally out of my field but I think at least with the double probe it is biased between the 2 electrodes and current across or through the sensor is measured. The bias voltage is varied to extract specific current v.s. voltage anomalies. Can be thought of as a source/measure device. The plasma is the current sense "resistor" albeit very non-linear but that's what your looking for right ?
Susskind (in The Theoretical Minimum, volume 1, pages 203-205) writes the Lagrangian for the magnetic field as ##L=\frac m 2(\dot x^2+\dot y^2 + \dot z^2)+ \frac e c (\dot x A_x +\dot y A_y +\dot z A_z)## and then calculates ##\dot p_x =ma_x + \frac e c \frac d {dt} A_x=ma_x + \frac e c(\frac {\partial A_x} {\partial x}\dot x + \frac {\partial A_x} {\partial y}\dot y + \frac {\partial A_x} {\partial z}\dot z)##. I have problems with the last step. I might have written ##\frac {dA_x} {dt}...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
