I Reading Paper on Earth Occultation Technique
The discussion focuses on the Earth Occultation Technique used in the Burst and Transient Source Experiment, specifically addressing the derivation of equations for occultation times found in Appendix B. There is a concern that some derivation steps may be missing and a request for sources where these equations might have been previously established. The completeness of Appendix B is debated, with some asserting it adequately assumes a spherical Earth and known satellite positioning, while others find Appendix C lacking, particularly regarding the WGS84 ellipsoid model. Recommendations for software tools like Starlink and SLALIB are provided for more accurate positional astronomy calculations. Overall, the conversation emphasizes the need for clarity and completeness in the technical derivations related to this observational technique.
yucheng
TL;DR Summary
I was reading a paper and I need help with the derivations of the equations for occultation timing. Where were these equations first derived?
The Burst and Transient Source Experiment Earth Occultation Technique​
https://www.semanticscholar.org/pap...hman/b4e57f91de6fec73fa680bcd7d6efbdf0de10bee
In **Appendix B**, the authors derive the equations for the occultation times. However, it appears that many steps were left out. I suspect that these equations were first derived elsewhere. Do you happen to know where? I have tried looking into the citations in the last paragraph of the **Introduction**, but to no avail (maybe I did not look carefully enough?) It might possibly be located in the Proceedings to the Gamma Ray Observatory Science Workshop...
Thanks in advance!
P.S. I am just trying my luck here {:-)
Astronomy news on Phys.org
Appendix B seems fairly complete to me. It assumes the Earth is a sphere and that seen from a satellite the Earth hides a circular area of sky. Since the position of the satellite relative to the Earth is known, the centre of the circular occultation is known. The height of the satellite decides the angular diameter of the occultation. The target, at an infinite range, effectively crosses the circle along a chord that probably never passes through the centre of the circle.
It is Appendix C that I find less complete. Since the WGS84 ellipsoid for the Earth is then being considered, I would use Starlink, or SLALIB: A Positional Astronomy Library;
http://www.ascl.net/1403.025
https://github.com/Starlink/starlink
Your observatory organisation probably has a license for a fully maintained version of the software system.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
