Ready for a Summer Math Challenge?
In summary, the conversation discusses a summer math challenge with various levels of difficulty. The rules state that solutions must be provided with proof and that outside resources are allowed. Several questions are posed, including one about trigonometric functions and another about car fueling, and their solutions are provided by different users. Other questions involve geometry, calculus, and probability. Lastly, a math puzzle about friends buying different colored and sized tops at a shopping center is presented. The summary concludes with a prompt to prove a statement involving matrices.
  • #36
QuantumQuest said:
It is just used in the context of explaining what is ##I_A##.
It is in the problem statement though. I think you have to replace it by ##\mathbb{R}.##
  • #37
We are in the context of ##\mathbb{R}## regarding ##f## but during the solution you can introduce ##I_A## as it is (i.e. in a more generalized fashion).
  • #38
I guess you can do that, but formally the other functions should be restricted to ##A## too if this is a proper subset of ##\mathbb{R}##. But it doesn't matter, I understood the question now.
Likes QuantumQuest
  • #39
Here's my solution for 7.
(a) Let ##X## be the variable that indicates "the amount of balls chosen before getting yellow". Then ##X## has a geometric distribution with parameter ##p = r+g+b = 1-y##, if we consider pulling a non-yellow ball as a failure, and it is well known that ##\mathbb{E}[X] = \frac{1}{r+g+b}##.
(b) Let ##Y## be the variable that indicates "the amount of different colors chosen before getting yellow". Then ##Y## can attain the values ##0,1,2,3##.
DISCLAIMER: I assume in this answer that all the quantities ##p,g,r,y## are non-zero. Otherwise, I would divide by zero and some of the series won't converge.
Then:
##\mathbb{P}\{Y = 0\} = y##
Write ##R_k## for the event "pulling red balls the first ##k## pulls", and define ##B_k## and ##G_k## similarly. Define ##Y_l## as the event "pulling a yellow ball the ##l^{th}## try".
Then,
##\mathbb{P}\{Y=1\} = \mathbb{P}(\bigcup_{k=1}^\infty (R_k \cap Y_{k+1})) + \mathbb{P}(\bigcup_{k=1}^\infty (B_k \cap Y_{k+1})) + \mathbb{P}(\bigcup_{k=1}^\infty (G_k \cap Y_{k+1}))##
##= \sum_{k=1}^\infty \mathbb{P}(R_k \cap Y_{k+1}) + \sum_{k=1}^\infty \mathbb{P}(B_k \cap Y_{k+1}) + \sum_{k=1}^\infty \mathbb{P}(G_k \cap Y_{k+1})##
##= y\sum_{k=1}^\infty r^k + y\sum_{k=1}^\infty b^k + y\sum_{k=1}^\infty g^k ##
##= y(\frac{r}{1-r} + \frac{b}{1-b} + \frac{g}{1-g})##
In the same way,
##\mathbb{P}\{Y=2\} = y(\frac{r+g}{1-(r+g)} + \frac{r+b}{1-(r+b)} + \frac{b+g}{1-(b+g)})##
##\mathbb{P}\{Y=3\} = y\frac{(r+g+b)}{1-(r+g+b)} =r+g+b##
so we obtain:
##\mathbb{E}[Y] = y(\frac{r}{1-r} + \frac{b}{1-b} + \frac{g}{1-g} + 2(\frac{r+g}{1-(r+g)} + \frac{r+b}{1-(r+b)} + \frac{b+g}{1-(b+g)})) + 3(r+g+b)##
and now I hope I'm not asked to simplify this :P
  • #40
I have a question about question 2. It says it is a one way ride. Do you get to choose the direction you are going?
Otherwise the answer seems that it is not possible, since it already fails for ##N=2##.
Also, do all the cans contain the same amount of fuel?
  • #41
I'll take a look at this tomorrow. From where I sit, this formally should be deleted because helpers aren't supposed to put in solutions until the 16th of the month. There is ambiguity on time zones for that rule, though I think we observe GMT (as in Greg Mean Time.)
edit: despite being impressed with myself on "GMT", I'm taking a look at the solution now.
edit2:
The solution stated is wrong. Your assumption that they are non-zero probabilities is fine by me.
I'll throw a couple bones your way:
For part 1 -- your answer is actually how I first answered the problem, but is wrong. Why?
For part 2 -- there is a very simple solution here that looks a lot nicer than your final formula. You are correct that the possible number of different colors seen before yellow is in ##\{0,1,2,3\}##. You may want to look at your formula on simple qualitative grounds.
For example what expected value of Y does it give in the uniform case?
  • #42
You may want to re-read the problem and prior comments in the thread on this problem... gas cans don't have uniform amounts of fuel in general .
You choose starting point but not direction. (The track is said to be "one way" meaning a pre defined direction. For fun I'll insist that the cars must go clockwise.)
Why do you think this fails for N=2?
  • #43
edit2:
Yeah, I made a dumb mistake for part 1.
Succes should be pulling yellow, so the expected value should be
1/p = 1/y
I will look at 2 later today, but is the formula correct as it stands? If not, I'm curious to see where I made a mistake.
  • #44
I was wrong and you are right. It doesn't fail for ##N =2##.
  • #45
1/p = 1/y
Part 1 is still not right but getting warmer. (I correct what I said earlier -- your current answer is what I initially thought of as the answer but a closer read of the question indicates otherwise)
Part 2 is wrong -- unless there is some mass cancellation I'm not seeing and a major transcription error in the below.
Python:
r_prob = 0.25
g_prob = 0.25
b_prob = 0.25
y_prob = 1 - r_prob - g_prob - b_probdef ev(r, g, b, y):
    part1 = r/(1-r) + b/(1-b) + g/(1-g)
    part2 = (r+g)/(1-(r+g)) + (r+b)/(1-(r+b)) + (b+g)/(1-(b+g))
    part3 = (r+g+b)
    return (part1 + 2*part2)*y + 3*(r+g+b)
print(ev(r_prob, g_prob, b_prob, y_prob))
# prints expected value of 4 which is impossible
compare against
  • #46
Python:
r_prob = 0.25
g_prob = 0.25
b_prob = 0.25
    part3 = (r+g+b)
compare against
EDIT:
I was confused by a different use of the geometric distribution. This is what happens when we become too lazy to calculate expectations :). I hope it is correct this time.
Corresponding to the probability function ##\mathbb{P}\{X = k\} = q^kp = (1-y)^k y##, we have
##\mathbb{E}[X] = \frac{q}{p} = \frac{1-y}{y} = \frac{r+g+b}{y}##
so this is the answer.
For (2), I discovered that my calculation for ##\mathbb{P}\{Y=2\}, \mathbb{P}\{Y=3\}## is wrong. I couldn't split up it in sums since the events aren't disjoint. Trying to correct that now.
  • #47
Math_QED said:
EDIT:
Correct. It can also be interpreted as a classic 0 vs 1 indexing error. What you (and I) originally did was count total draws, but the question wants to count total failures -- hence it is the prior answer minus one, i.e. ##\frac{1}{p} - 1 = \frac{1-p}{p} = \frac{q}{p}##
  • #48
Solution for 2, the one I gave a hint towards already:
Consider a modified problem where negative fill values for the tank are allowed. Start at an arbitrary place with 0 fuel, keep track of your fuel. You get a function that decreases with a constant slope (your fuel consumption) most of the time and does a finite number of discrete jumps upwards at the fuel talks. After the full length you are at zero again (or higher if we have excess fuel). If you keep the position of the fuel tank as part of the previous segment then every segment has a minimum and you can find a global minimum. Start at this global minimum and your tank will always have fuel.
I mentioned the infinite case already, so let's have a look at this. Let's say the length of the track is 1. Put ##2^{-n}## fuel at position ##2^{-n}## for n=1 to infinity. The total fuel is 1. If you don't start at a fuel tank then you cannot drive. If you start at a fuel tank you have just enough fuel to reach the next fuel tank - until you get to 1/2 at place 1/2, which brings you to position 1 (or equivalently: 0) exactly - but there is no fuel tank there, you cannot continue. This is a purely mathematical result, obviously.
Likes QuantumQuest and StoneTemplePython
  • #49
As a slightly more physical take: you could ask that your friend gets in the car the 'day' before and starts with a full tank at a canister and logs consumption vs amounts available at each canister. Reading these logs in line with the above would give you 'an inside tip' afterward and ensure you choose the a starting spot guaranteed to succeed.
A few other thoughts:
1.) There's at least two other ways to prove the existence of a 'good' starting spot -- via induction and a contradiction involving 'pigeons'...
2.) Any discussion of infinite dimensional cases forces structural issues not in the problem -- the other two techniques aren't designed for it, and the existence of a global minimum partial sum (not merely a greatest lower bound) becomes troublesome. In any case, it's really outside the scope.
3.) This question, with ##n## canisters, under a slightly different guise, has been asked of many maths students interviewing with Cambridge (undergrad I think). It's a nice problem though kind of rough to have thrown at you on the spot.
  • #50
My solution for Problem 3
γ=45-α/2
β=135-α/2
According to the Law of sines:
##\overline{AD} = \frac {\overline{CD} \sin(45-α/2)}{\sin(α/2)}## 1
##\overline{AD}= \frac {\overline{BD}\sin(135-α/2)}{\sin(α/2)}## 2
multiplying eqs1 and eqs2 and using that ##\overline{AD}^2=\overline{BD} \overline{CD}##,
##\sin(45°-α/2)\sin(135°-α/2)=\sin^2(α/2)##
The solution is α/2=30°: α=60, β=105°, γ=15°.
Dividing eq 1 with eq 2
##\frac{\overline{BD}}{\overline{CD}} = \frac {\sin(45°-α/2)}{\sin(135°-α/2)} =\frac{\sin(15°) }{\sin(105°)} = \tan(15°)##
Using the half angle formula :##\tan^2(x/2) =\frac {1-\cos(x)}{1+\cos(x)}## . With x=30°, ##\tan(15°)=2-\sqrt{3}##.
  • #51
γ=45-α/2
β=135-α/2
I have such a nice way for ##\tan(15°)=2-\sqrt{3}## with the cosine theorem and all just look up the tangent. :cry:
Correct, of course.
  • #52
Correct, of course.
I do not know what is that way, but this is an other one for tan(15°)
Likes jim mcnamara and fresh_42
  • #53
For question 7, part 2, I don't see the simple solution, but I submit this:
I'm going to change the notation slightly to ##y, a, b, c##, as that's the way I've written it out.
First, we have:
##E = aE(a) + bE(b) + cE(c)##
Where ##E## is the expected number of colours before we get a yellow and ##E(a)## is the expected number of colours we get before a yellow, given the first ball is colour ##a##.
Now, let's focus on ##E(a)##. This doesn't change if we draw ##a## again, so we have:
##E(a) = \frac{1}{y + b + c}(y + bE(ab) + cE(ac))##
Where ##E(ab)## is the expected number of colours before we get a yellow, given that the first ball was ##a## and the next ball of a different colour was ##b##. Also, note that ##y + b + c = 1-a##.
Finally, ##E(ab) = \frac{1}{y + c}(2y + 3c)##
If we put this all together, we get:
$$E = \frac{a}{1-a}(y + b(\frac{2y + 3c}{y+c}) + c(\frac{2y + 3b}{y+b})) $$
$$\ \ \ + \frac{b}{1-b}(y + a(\frac{2y + 3c}{y+c}) + c(\frac{2y + 3a}{y+a}))$$
$$\ \ \ + \frac{c}{1-c}(y + a(\frac{2y + 3b}{y+b}) + b(\frac{2y + 3a}{y+a}))$$
I checked this with ##y = a= b = c = 1/4## and got ##E = 3/2##.
But, a simplification of this result I don't see.
  • #54
Problem 4
The distance between A and P is x=3tan(θ). The speed of the spot of light is v=dx/dt= (3/cos2(θ))dθ/dt.
There are 5 turns in 60 s, so dθ/dt= 5 *2π/60=π/6 s-1.
At the instant, when AP=4 mi, the distance LA = 5mi, and cos(θ)=0.6. The speed is v=(3/0.36)(π/6)=π/0.72=4.36 mi/s
Likes QuantumQuest
  • #55
Simple solution to number 7:
We pick the balls at random for a large number of trials and count how many different colours we get between yellows. The probability that colour ##a## appears before the next yellow is ##\frac{a}{a+y}##, so ##a## counts with this frequency. Similarly for ##b## and ##c##.
The expected number of coloured balls between yellows is the sum of these three:
##E = \frac{a}{a+y} + \frac{b}{b+y} + \frac{c}{c+y}##
I checked the two formulas for ##a = b = 1/4, c = 1/8, y = 3/8## and got ##E = 21/20## in both cases. So, I guess the expression in my previous post does indeed simplify to this one!
Likes StoneTemplePython
  • #56
your original approach was a nice use of conditioning but a really awful final answer -- it was too long for Wolfram to parse and sympy couldn't reduce the difference between these two solutions to zero. However, I ran a long MC simulation a few minutes before you posted this which convinced me they were the same formula.
The simple idea here is let ##N ## be a random variable taking on values for number of different colors seen before yellow. ##N## can take on values of 0, 1, 2 or 3. We can write ##N## numerous ways but in general the most convenient is to decompose it into (possibly dependent) indicator random variables.
##N = \mathbb I_a + \mathbb I_b + \mathbb I_c##
where, for example, ##\mathbb I_a## is an indicator random variable (bernouli) that is ##1## in the event an "##a##" ball is drawn before a ##\text{yellow}##, and ##0## otherwise. Taking expectations of each side gives
##E\big[N\big] = E\big[\mathbb I_a + \mathbb I_b + \mathbb I_c \big] = E\big[\mathbb I_a\big] + E\big[\mathbb I_b\big] + E\big[\mathbb I_c \big] = \frac{a}{a+y} + \frac{b}{b+y} + \frac{c}{c+y}##
Likes PeroK
  • #57
I was convinced they were equivalent because both methods looked rock solid to me! But the first formula was frustratingly difficult to simplify.
  • #58
quite right -- though I always worry about a small bug creeping in throwing the results off.
I ended up tweaking the sympy setup and getting symbolic equivalence -- for those interested I've dropped in the code. The exact steps to do the simplifications by hand are, of course, left as an exercise for the interested reader.
Python:
import sympy as sp
a = sp.Symbol('a', positive = True)
b = sp.Symbol('b', positive = True)
c = sp.Symbol('c', positive = True)
y = sp.Symbol('y', positive = True)
part1 = a/(1-a)*(y +b*(2*y+3*c)/(y+c) + c*(2*y + 3*b)/(y+b))
part2 = b/(1-b)*(y + a*(2*y+3*c)/(y+c) + c*(2*y+3*a)/(y+a))
part3 = c/(1-c)*(y + a*(2*y + 3*b)/(y+b) + b*(2*y + 3*a)/(y+a))
perok_formula = part1 + part2 + part3
print(sp.latex(perok_formula))
# prints formula out in latex
desired_formula = a/(a+y) + b/(b+y) + c/(c+y)
difference = desired_formula - perok_formula
print(sp.simplify(difference.subs(y, 1 - a - b - c)))
# prints zero
Likes jim mcnamara
  • #60
what about the gas canisters problem in our last basic challenge? It was problem 2:
https://www.physicsforums.com/threads/basic-math-challenge-july-2018.950689/
Hey, Mr. StoneTemplePython, thanks a lot for burning up all my spare time! :wink: I took a look at the problem and solving it became an obsession.
I didn't look at your solution or anyone else's until after coming up with my own (and I learned that email alerts don't honor the SPOILER codes, so I had to avert my eyes to that portion of your message). Actually, I haven't read any of the other answers except yours.
I often get caught by misreading the problem or making the wrong assumptions or failing to make the right assumptions.
For example, I assumed all canisters hold the same amount of fuel, since assuming otherwise would definitely put the problem out of my reach. I assumed you couldn’t just get out of the car, go fetch a canister and bring it back, or else the problem would be trivial—you have to drive to the next canister (technically, there's nothing forbidding this, so you couldn't mark such an answer wrong). My initial reading of “mischievously placed” was that you would plant the car next to a canister and then the rest would be positioned in the worst possible place. I backed off this assumption as it’s easy to see that you can’t ever win. Finally, I assumed the car's tank could hold all the fuel in all the canisters without overflowing.
I came up with something like your solution, but I don't think your solution is complete. Consider the 4-canister case. I place two canisters together and another two together such that the distance between them is greater than two intervals. Your argument fails. Of course, if one pair is separated by more than two intervals, then other pair will be separated by less, so you start with the second pair. The choice of the starting canister is important and I didn't see it addressed at all by your argument. The 3-canister case is misleading since the choice of the correct starting position is obvious. When you get to the 100-canister case, things are even trickier.
Here's my solution:
Divide the track into N open-ended equally-sized segments. Let’s begin by placing one canister at each end point of a segment. The canisters are equally spaced and the car runs out just as it reaches the next canister. Solution: the car can be placed next to any canister.
Every alternative placement can be formed by warping this arrangement, sliding canisters in the direction of travel by some distance. Take the canister immediately after the one at the car’s starting position and move it further away (moving it closer wouldn’t change anything). We don’t jump over any existing canister—since canisters are arbitrary, any arrangement achieved by a jump could also be achieved by sliding canisters without jumping.
If we move the car’s starting position to the moved canister, we can complete the track. It's important to visualize this. The canisters started out equally spaced. As we create a gap, if we switch our perspective to the gap's end point, we see all the canisters in front of us and occupying less space than before. We will have all the fuel we need before we reach the gap at what is now the end of our route.
We can keep moving the canister further away, gathering up or compressing the distance between any other canisters we meet and the situation remains the same. Actually, if the gap creates one empty segment, we can move the car's starting position to any canister except the one preceding the gap. If the gap creates two empty segments, then any position except the two preceding the gap will work. And so on. The position at the end of the gap always works.
Try to create an uncrossable gap elsewhere. The new gap cannot affect the existing gap. It could, of course, but I never specified how big the first gap was, so any situation which shrinks the first gap could be equated to a situation where the first gap was always that size.
If we compressed all canisters into the last segment, then we cannot create a gap big enough to be a problem.
If we compressed the canisters into the last two segments, then remember that either of the first two canisters will get us around. The biggest gap we can create is two segments. If we place this gap after the first canister, we can finish by starting from the second canister. If we place it after the second, then the first two canisters get can us across the gap, since the gap can't be bigger than 2. Placing the gap any further along won’t help. We'll just have even more fuel to cross the gap.
The same generalizes if we compress all the canisters into the last n segments. The gap can't be bigger than n and no matter where we put it, we can either cross it or choose a starting position after the new gap that will carry us around.
Admittedly, I've solved the problem for N canisters with 1 or 2 gaps. There also needs to be a generalization for n gaps, showing that a similar argument could be applied for any additional gaps, but my brain is tired and so I'll leave it as an exercise for the reader.
  • #61
Yes, I can certainly relate to this. Figuring out how to break the abstraction into something useful can take a little or an awful lot of time. That's kind of the joy, and peril, of these challenges I think.
I also didn't realize that Spoilers aren't hidden in emails... interesting.
For example, I assumed all canisters hold the same amount of fuel, since assuming otherwise would definitely put the problem out of my reach...
Sorry no. Your assumption isn't justifed. The canisters in general hold a varying amount of fuel. The only constraint is that of course each amount is real non-negative and in aggregate the amount of fuel sums to exactly the amount required to drive around the track. (There is a way to convert from your not justified assumption to the actual problem by changing perspective and just looking at partial sums though... edit: specifically if you consider for any arbitrarily chosen starting position then the ith 'gas station' has ##x_i## of gas and ##y_i## as the gas required to get to the next station -- the value of ##z_i:= (x_i - y_i)## is what is of interest.)
Your 'counterexample' doesn't hold water I'm afraid. If you place two canister touching each other (I guess that's what 'together' means?) then it's just another legal 4 canister configuration. If together means 'exactly the same spot' I'm not really sure that's allowed physically but in the interest of sport I'd point out that if it were allowed you have just reduced it to the 2 canister problem which most people can solve by inspection.
edit: thread was moved to the right home so suggested place for follow-ups is not needed.
note: some of your questions and confusions were already asked and answered in that thread.
another note: even if you've been out of the habit of doing math for many decades, in the event you've been doing computer programming in the interim, my suggested solution should feel quite familiar to certain recursive programs.
All in all I think we agree that this is a nice Basic Challenge
Likes pbuk and Greg Bernhardt
  • #62
"At the same spot relative to the track" is what I meant. The canisters could be stacked on top of each other, for example.
As for my counter-example, I mixed my problem statements and was still thinking in terms of the one I working on. I interpreted "extra fuel" to mean more than 1/Nth of the total fuel, rather than more than 100% of the fuel needed for the next section. It took me a while to even see this.
Reading your problem description more carefully, I see you asked if there was a viable starting point, not to identify which point that might be. The reduction proof works for identifying that a starting point exists, but not for identifying which it is. Oddly enough, it is not the one with the most fuel or even the most percentage of fuel for its leg. Consider N=4 where all canisters are spaced equidistant. The fuel amount needed to complete the track is 100 and the canister amounts are 26, 51, 12 and 11. Staring at 26 let's the car finish; starting at 51 doesn't. In same cases, of course, there are multiple valid starting points. When reducing, it doesn't matter whether you start with 26 or 51—you still know it can be done, but a little extra record-keeping is needed to determine where to start.
I do think the problem should have explicitly stated that the fuel was not distributed equally among all canisters. If you argue that I should, in my solution, not include restrictions not imposed by the problem statement, then I will simply have the driver walk to the nearest canister, bring it back to the car and repeat as necessary. Problem solved! If you argue that I shouldn't make unreasonable assumptions, then I would respond that reasonable is a subjective term; if something is important to the problem, it should be included. Personally, I don't think it would hurt to include both.
Thanks for taking the time to create this puzzle, though (assuming it's yours).
  • #63
In mathematics it's called an existence proof. Nothing more and nothing less.
And yes, it is immediate from my suggested inductive proof that such an approach only shows the existence of a viable path -- but you could have to to try all ##n## starting points to find one that works. This is why in our August thread I said mfb's response here (see post 48 and 49 on this thread) is perhaps the most constructive / satisfying -- it gives existence and a thought experiment to identify the starting point.
It doesn't not work like that. You should read through these threads and see how people respond in them. As we've said many times in these threads -- you are free to ask questions. You are not free to over-ride the challenges or their intent.
This puzzle actually comes in 2 different problem books I have. It is not an original of mine. As I said in post #49 of this thread -- a slight variant of this has been asked on many occasions as part of mathematics admissions interviews at Cambridge. I think what you've said above... would have been quite poorly received. What you are suggesting here seems to be in between linguistics and personal philosophy, not math.
Additional points:
Point 1:
two posts up I gave a direct way to convert from your unjustified assumption to the actual problem -- if you view the problem in said light, then as I've said, whether the amounts of fuel in each canister are constant or not is irrelevant. Given that you are arguing about linguistics I suppose you didn't understand this.
Point 2:
If you need something even more direct: you are free to ask questions and even ask about making certain assumptions. If the person who submitted the question says ___ assumption is fine, then it is fine. If you are told it is not fine then it is not fine. That's how the challenges work. Period. This is a math challenge -- I will not "argue" that you shouldn't make ___ assumption. If it is my problem, I will tell you, as I've already done in this thread. Case closed.
  • Math Proof Training and Practice
14K
11K
13K
