Real Analysis convergence proof
In summary, the proof provided assumes what needs to be proven and does not fully explain why epsilon can be chosen in that way. A valid proof would need to explain why epsilon can be chosen such that |yn + b| < epsilon/2 and how K is related to M and L to show that xn - yn converges to a - b. The crucial step in the proof is the use of the triangle inequality.
elimenohpee
67
If the sequence xn ->a , and the sequence yn -> b , then xn - yn -> a - b
Can someone check this proof? I'm aware you cannot subtract inequalities, but I tried to get around that where I indicated with the ** in the following proof. Does this make sense?
(for all epsilon > 0)(there exists a natural number K)(such that for all n > K) |(xn-yn) - (a-b)| < epsilon
|(xn - a) - (yn - b) | < epsilon
|(xn - a) + (-yn + b) | < epsilon **
choose 1.) |xn - a| < epsilon / 2
and 2.) |-yn + b| < epsilon / 2
1.) + 2.)
|(xn -a) + (-yn+b) | <= |xn - a| + |-yn +b| < epsilon
is this a valid proof?
All seems good, however:
I think you still need to explain why you can choose an epsilon such that |yn+b|< epsilon/2.
It is indeed true that -yn converges to -b, but you still need to prove it! (even if it's trivial :biggrin:)
great, thanks! and point taken lol :D
1.) + 2.)
This the sort of thing you write on scratch paper to figure out a strategy for the proof you will submit for grading. What you have here assumes what you want to prove. It's sort of the reverse of your final proof.
The crucial step here is |(xn -a) + (-yn+b) | ≤ |xn - a| + |-yn +b| the triangle inequality.
And of course: |xn - a| + |-yn + b| = |xn - a| + |yn - b| .
To go forward,
Let ε > 0 .
Then since xn converges there is some L that works for xn, a and ε/2
Similarly, there is some M that works for yn, b and ε/2​
Now, show how K is related to M & L to show that xn - yn converges to a - b .
FAQ: Real Analysis convergence proof
Q1: What is real analysis convergence proof?
Real analysis convergence proof is a mathematical technique used to prove that a sequence of real numbers converges to a certain limit. It involves using precise definitions and logical reasoning to show that the terms of the sequence get closer and closer to the limit as the number of terms increases.
Q2: How is real analysis convergence proof different from other types of convergence proofs?
Real analysis convergence proof focuses specifically on sequences of real numbers, while other types of convergence proofs may deal with different types of numbers or objects. Real analysis convergence proof also relies on the use of real analysis concepts such as limits, continuity, and convergence, which may not be present in other types of proofs.
Q3: What are some common techniques used in real analysis convergence proof?
Some common techniques used in real analysis convergence proof include the use of the definition of a limit, the squeeze theorem, and the Cauchy criterion. These techniques involve manipulating the terms of the sequence and using precise definitions to show that the terms get closer and closer to the limit.
Q4: What is the importance of real analysis convergence proof?
Real analysis convergence proof is important because it allows us to rigorously prove that a sequence of real numbers converges to a specific limit. This is useful in many mathematical and scientific applications, as it allows us to make accurate predictions and draw conclusions based on the behavior of a sequence.
Q5: What are some common challenges when performing a real analysis convergence proof?
Some common challenges when performing a real analysis convergence proof include determining the appropriate techniques to use, understanding and manipulating complex definitions, and ensuring that the proof is logically sound. It may also be challenging to find the right balance between providing enough detail and being concise in the proof.
