- #71
Hans de Vries
- 27
Realize that the characteristic speed is only 1 meter/second in the example withMentz114 said:Hi Hans,
as far as I can see you have only 'proved' that an observer from a moving frame will see a wave packet contracted. This is not surprising because its momentum observed from the moving frame is different. Lorentz contraction is a function of the relative velocity between the frames and so cannot be real in the sense that in the rest frame of the wave packet something changes.
Suppose I am in my kitchen eating a shami kebab, and being watched by someone from a spaceship at rest wrt to me. They zoom off and reach a high velocity; according to you my kebab shrinks to half its previous length. But what about all the other 'observers' in the universe. Are you saying that my kebab will vary in size according my relative velocity wrt them also ? That's more like a sort of Machian kebab principle than Lorentz contraction.
The only things I can regard as real are those that are agreed by all (IRF) observers. Einstein's principle of covariance explicitly states that anything that can be altered by a change of coordinates ( eg LT) is not a real physical effect !
the spring/mass grid.
Another example is that of the rubber sheet: If you press your finger in a rubber
sheet then it deforms in a circular symmetric way. However, if you move your finger
in a straight line then the deformation becomes a "Lorentz contracted" oval.
Again, this happens with respect to the slow mechanical propagation speed in the rubber.
Mentz114 said:There was a young man called Hans
who thought he could tell at a glance
that things on the move
(it is easy to prove)
are somewhat in length a bit sans
Sorry I had to use French.
Sans problème
