Realistic Capacitor with leaking dielectric
A realistic capacitor filled with dielectric experiences leakage due to the dielectric's conductivity, resulting in a gradual loss of charge over time. The problem involves a parallel-plate capacitor with area A and distance d, initially charged to voltage V0, which decreases to V(τ) = V0/e after time τ. To find the conductivity σ of the dielectric, one can treat the leakage as a parallel resistor connected to the capacitor. The key equations include the capacitance C = κC0 and the relationship σ = 1/ρ. Understanding this setup is crucial for solving the problem effectively.
yango_17
A realistic capacitor is almost always filled with dielectric, but invariably this dielectric will conduct just a little, and the charge stored on the capacitor's plates will "leak." Over time, quite a bit of current can leak away. A good capacitor has a small leakage current.
Consider a parallel-plate capacitor with the plates of area A and distance between them d, filled with a dielectric with the dielectric constant κ. At t=0, some charge is put on the capacitor so that it's voltage is ##V_{0}##. At some later time ##\tau =t##, the voltage on the capacitor is ##V(\tau )=\frac{V_{0}}{e}## (where e is Euler's constant). What is the conductivity σ of the dielectric?
##C=\kappa C_{0}##
##\sigma=\frac{1}{\rho }##
##R=\frac{V}{I}##
I would like to know how to begin to set up the problem. I'm not sure how to go about finding a relation between the voltage of the capacitor and the conductivity of the dielectric, especially when one has to take into account the "leaking" of the dielectric. Any help getting started on this problem would be appreciated. Thanks!
You can handle the leakage as if a resistor was connected parallel to the capacitor.
Ah, that's a great hint. Alright, I'll see how far I can take it from here
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
