- #36
DrChinese
- 1,944
kurt101 said:1. I have never heard of a counter example where bell violating entanglement was not prepared through local preparation.2. If you have photon pair A and B that are entangled through SPDC and photon pair C and D that are entangled through SPDC and you have B and C interact locally, then I would say A and D are not entangled prior to B and C interacting locally and are not entangled after B and C interacted locally. If you want to say A and D are entangled right when B and C interact, that is fine with me, but using a realistic description, I would say that the local interaction at B and C drops the previous entanglement B had with A and C had with D and creates a new entanglement between B and C.
1. For example:
https://arxiv.org/abs/0911.1314
Theory: Characterizing the nonlocal correlations of particles that never interacted
https://arxiv.org/abs/0809.3991
Experiment: High-fidelity entanglement swapping with fully independent sources
https://arxiv.org/abs/1606.07503
Experiment: Entanglement Swapping with Independent Sources over an Optical Fibre Network
[Edited to include experimental sources in addition to theoretical treatment; see post #37 by PeterDonis.]2. A and D become entangled. Does that entanglement occur before or after B & C interact? No one can say, as the timing of the B/C interaction does not change the outcome. Earlier or later, makes no observable difference.
However, that is not relevant to your premise 3. In that, you say A & D must be entangled by a local interaction. They have no interaction at all. The are never even present in a common light cone, as they are created by independent SPDC sources that are "distant" to each other. So how can there be a local realistic description of A & D becoming entangled so that there spins are 100% correlated when measured at any chosen angle?
Your premise requires their hidden variables to be set at their creation - and they will NOT be entangled unless something else occurs after they are on their merry way to the detectors. In a local realistic world, they are totally immune from such later influence (if they are sufficiently far apart).
