Really confused about voltage and some other quetions
In summary: Yes, voltage is the energy required by the electrostatic forces between 2 points to move a certain quantity of charge between them. 2. Potential difference is the difference in potential energy between two regions of opposite net charges. 3. Current, when the current is of a higher magnitude, do the electrons flow faster within a certain imaginary plane at a given time or just that there are are more electrons? does the speed of current vary in a circuits? 4. If resistance in a circuit is zero, does this mean there can not be any voltage? V = I * R and the multiplicative property of 0. Or is it not possible to not have 0 resistance?5. The "WORK D
Logical Dog
362
97
Please explain how or why (I have zero knowledge in physics)..
1. is Voltage the energy required by the elctrostatic forces between 2 points to move a certain quantity of charge between them?
2. Why is it called potential difference? Does this have to do with the difference in potential energy between two regions of opposite net charges? Why? In mechanics as I learned potential energy is the energy an object has due to its shape or position (change in PE= Change in H * G*M), what does this mean in a circuit?
5. What is meant by thsi statement "IN engineering the current direction describes the net positive flow"?
6. Is thE " WORK DONE" to move one charge to another region of net opposite charge given by multiplying the ([Q1*Q2/R^2]*k)* distance between the charges? what does this have to do with voltage?
7. Why is the source of voltage always having a voltage of 0, is this because it is the "lowest" point much like an object on a ground has 0 potential energy? because distance between charges is very little at the source, but they have to travel through a wire or other medium, so why is voltage 0 for the source and this is the standard for comparision for other elements.
9. If electrons don't have the speed everywhere in the circuit, doesen't it mean their KINETIC ENERGY is changing and the work done by electrostatic forces increases? this would increase the voltage, yes?
"A difference in electrical charge between two regions and a medium between them to allow flow of electrons is enough to establish a current, a creation of voltage leads to a flow of current" is a correct statement?
FAQ: Really confused about voltage and some other quetions
What is voltage?
Voltage is a measure of the electrical potential difference between two points in a circuit. It is often referred to as the "pressure" that drives the flow of electrons.
How is voltage measured?
Voltage is typically measured using a voltmeter, which is a device that measures the potential difference between two points in a circuit.
What is the difference between voltage and current?
Voltage and current are two different physical quantities that are related to each other in an electrical circuit. Voltage is the potential difference that drives the flow of current, while current is the rate of flow of electric charge.
How does voltage affect the performance of electronic devices?
Voltage plays a crucial role in determining the performance of electronic devices. Too high or too low voltage can damage the device or cause it to malfunction.
What are the units of voltage?
Voltage is measured in volts (V) in the International System of Units (SI). In some countries, voltage may also be measured in kilovolts (kV) or millivolts (mV).
