Really getting started precal, physics problem
  • Thread starter Thread starter bennett
    Physics
To determine the airplane's speed relative to the ground, one must combine the airplane's velocity vector and the wind's velocity vector. The airplane travels at 400 kilometers per hour with a bearing of 45 degrees, while the wind has a velocity of 40 kilometers per hour at a bearing of N50E. Establishing a consistent coordinate system is crucial for resolving these vectors into their x and y components. The airplane's bearing is considered with respect to the air's velocity, meaning it is measured clockwise from the wind's direction. Properly adding these components will yield the resultant velocity of the airplane relative to the ground.
bennett
an airplane's velocity with respect to the air is 400 kilometers per hour, with a bearing of 45degrees. The wind at the altitude of the plane has a velocity of 40 kilometers per hour with a bearing of N50degeeesE. What is its speed relative to the ground
Ok I am not asking you to do the problem for me i just don't have all my notes on me and the book isn't much help I would really appreciate it if someone could help me get started on this problem, thanks.
Add the plane's velocity (a vector) to the air's velocity (another vector) to get the plane's velocity (the resultant vector).
One has to pick a coordinate system, e.g. N (+y), E (+x), S (-y), W (-x), and be consistent.
N50E means 50 degrees toward the east from N.
One has to resolve the velocity vector into two normal components (x, y) and add or subtract corresponding x and y components of the two vectors.
"an airplane's velocity with respect to the air is 400 kilometers per hour, with a bearing of 45degrees." Does this mean with respect to the air's velocity? I.e. is the bearing of the plane 45 degrees clockwise from the bearing of the air?
The magnitude of the velocity (speed) is with respect to the air, the orientation is with respect to the coordinate system, which is irrespective (independent) of the media (air) in which the airplane is traveling.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
