Reason for glass rod losing electrons
In summary, when rubbing occurs between glass and silk, heat energy is produced which provides the energy needed to free up electrons in outermost orbits of atoms in silk or glass. However, silk has tightly bound electrons in its outermost orbit, preventing them from being freed, while glass has less tightly bound electrons, allowing them to be freed. This results in a net transfer of electrons from the glass to the silk, leaving the glass positively charged and the silk negatively charged. This is known as the triboelectric effect.
vcsharp2003
897
177
When a glass rod is rubbed with silk cloth then it becomes positively charged, while the silk cloth becomes negatively charged. Why does glass rod lose electrons to silk cloth?
None
I am not sure if the explanation below is enough. This is a high school level question.
When rubbing occurs between glass and silk, then heat energy is produced which provides the energy needed to free up electrons in outermost orbits of atoms in silk or glass. But silk has very tightly bound electrons in outermost orbit which prevents the electrons from freeing up, whereas glass has less tightly bound electrons in outermost orbit and the energy is sufficient to free the electrons in outermost orbit.
Say two charge neutral materials touch, one could become positive charged with other negative due to energy level difference of electrons. The two keep charged after separation. I hope this is a rough sketch of the phenomena.
What is energy level of an electron in an atom? Is it the electrical potential energy of an electron?
While this might happen to some degree, I think the main cause is the difference in electrochemical potential between the two different materials.
You mean the silk cloth has a higher electric potential than glass rod?
Per wiki: https://en.wikipedia.org/wiki/Triboelectric_effect
Although the part 'tribo-' comes from the Greek for "rubbing", τρίβω (τριβή: friction), the two materials only need to come into contact for electrons to be exchanged. After coming into contact, a chemical bond is formed between parts of the two surfaces, called adhesion, and charges move from one material to the other to equalize their electrochemical potential. This is what creates the net charge imbalance between the objects. When separated, some of the bonded atoms have a tendency to keep extra electrons, and some a tendency to give them away, though the imbalance will be partially destroyed by tunneling or electrical breakdown (usually corona discharge). In addition, some materials may exchange ions of differing mobility, or exchange charged fragments of larger molecules.
Unfortunately I don't know enough about this topic to discuss it in more detail.
Edit: Just realized this was in the homework section, else I wouldn't have answered since I don't know too much about this phenomenon.
Likes vcsharp2003
It seems that electrons are unstable in outermost orbit if that orbit is not fully occupied and will therefore be in a higher energy state i.e higher electrochemical potential. If outermost orbit is fully occupied then electrons are in a stable state and have a lower electrochemical potential.
From what I remember, the number of electrons in an orbit is ##2n^2## where n can be 1,2,3,4 or any postive integer.
vcsharp2003 said:
Homework Statement:: When a glass rod is rubbed with silk cloth then it becomes positively charged, while the silk cloth becomes negatively charged. Why does glass rod lose electrons to silk cloth?
Relevant Equations:: None
I think the above explanation is incorrect because:
1) 'heat energy' is not responsible for the electron transfer;
2) the process is more complex than can be explained by simply considering individual atoms and their electrons. (Also, silk is a complex polymer containing several diffferent types of atom.)
This is a rather unfair question unless you have actually studied triboelectricity.
For high school level I would just say something like this:
The silk has a larger affinity for electrons than does the glass. Rubbing enables some outer atomic electrons to be transferred. Therefore there is a net transfer of electrons from the glass to the silk. This leaves the glass positive (overall more protons than electrons) and the silk negative (overall more electrons than protons).
Out of interest, note that the correct term for the production of charge through friction/contact is the triboelectric effect. Different materials have different affinities (affinity = liking) for electrons and this gives rise to a triboelectric series for a given set of different materials e.g.
https://engineerblogs.org/wp-content/uploads/2011/04/quiz_tribolelectric.jpeg
And Wikipedia says this:
“After coming into contact, a chemical bond is formed between parts of the two surfaces, called adhesion, and charges move from one material to the other to equalize their electrochemical potential. This is what creates the net charge imbalance between the objects. When separated, some of the bonded atoms have a tendency to keep extra electrons, and some a tendency to give them away, though the imbalance will be partially destroyed by tunneling or electrical breakdown (usually corona discharge). In addition, some materials may exchange ions of differing mobility, or exchange charged fragments of larger molecules“
Also, do not confuse electrochemical potential with electric potential. They are not the same thing.
Likes vcsharp2003
Thankyou for a detailed explanation.
Triboelectricity is new to me and not even in our textbook.
Likes Steve4Physics and berkeman
FAQ: Reason for glass rod losing electrons
What is the reason for a glass rod losing electrons?
The reason for a glass rod losing electrons is due to the process of triboelectric charging. When two materials come into contact and then separate, electrons can transfer from one material to the other, resulting in one material becoming positively charged and the other becoming negatively charged. In the case of a glass rod, friction with another material can cause it to lose electrons and become positively charged.
Why does a glass rod lose electrons when rubbed with certain materials?
This is due to the difference in electron affinity between the glass rod and the material it is being rubbed with. Materials with a higher electron affinity, such as rubber or fur, will have a stronger pull on the electrons of the glass rod, causing it to lose electrons and become positively charged.
Can a glass rod regain its lost electrons?
Yes, a glass rod can regain its lost electrons through contact with another material with a lower electron affinity. This will result in the transfer of electrons from the material to the glass rod, neutralizing its charge.
What factors can affect the amount of electrons lost by a glass rod?
The amount of electrons lost by a glass rod can be affected by the type of material it is being rubbed with, the surface area of contact, and the force of friction applied. Materials with a higher electron affinity, larger surface area of contact, and greater force of friction can result in a greater loss of electrons from the glass rod.
Is the loss of electrons from a glass rod permanent?
No, the loss of electrons from a glass rod is not permanent. Electrons can be transferred back to the glass rod through contact with another material with a lower electron affinity, or through grounding, where excess electrons are transferred to the ground.
