Reasoning in Deriving the Ultraviolet Catastrophe
In summary: But even though every mode has an equal average energy, it does not follow that every mode exist within the cavity. Why might it not be more likely, as in the QM calculation, that a mode of higher frequency is not as common as the lower frequency modes?There are several reasons why it might not be more likely for a mode of higher frequency not to be as common as a mode of lower frequency. First, high-frequency modes might be shorter-lived than lower-frequency modes, so they would be less likely to be encountered. Second, high-frequency modes might be more difficult to create in the cavity, so they would be less likely to be present. Third, high-frequency modes might be less common in the
center o bass
560
When one derives the ultraviolate catasrophe one looks at a cavity of perfectly conducting walls and with standing electromagnetic waves. Since these waves must vanish at the walls of the cavity, the wavelengths of the radiation is restricted according to the dimensions of the cavity: for example for a cubic cavity of length ##L## we must have
$$ n_i \frac{\lambda_i}{2} = L; i = 1,2,3;$$
where ##n_i## must be positive integers.
In other words, the walls of the container makes each mode of the electromagnetic waves be defined by a vector of positive integer components: ##\vec n = n_1 \vec e_1 + n_2 \vec e_2 + n_3 \vec e_3##.
The way one now proceeds is to find how many modes there are in the volume of an octant shell of witdth ##dn## in ##\vec n##-space, which expressed in terms of frequency is given by
$$ dN(\nu) = \frac{4 \pi V \nu^2 }{ c^3 },$$
where ##V=L^3## which by associating ##1/2 k T## of energy to each degree of freedom, gives an energy density per unit frequency of
$$u(\nu) = \frac{8 \pi \nu^2}{c^3}.$$
The Ultraviolet catastrophe now arises by going to the total energy density in the cavity given by
$$\int_0^\infty \frac{8 \pi \nu^2}{c^3} d\nu = \infty.$$
The quantum mechanical calculation saves us from this result by the fact that it is not equally probable for each mode to exist: in fact the probability of a mode of frequency ##\nu## is given by
$$\frac{1}{e^{h \nu/kT} -1 }.$$
Now here comes the question: in the QM calculation the modes are not assumed to be equally populated but are cut off by the factor ##\frac{1}{e^{h \nu/kT} -1 }## at high frequencies. What is the reason for assuming equally populated modes in the classical calculation?
As jtbell says, the equipartition theorem shows that (classically) thermal equilibrium can only be reached when every mode has an equal average energy. Therefore another way of stating the ultraviolet catastrophe is that according to classical mechanics a cavity with finite energy can never reach thermal equilbrium; rather, thermal interactions should distribute the electromagnetic energy in the cavity to higher and higher frequencies over time.
Probably none, esspecialy the infinite frequency is rather quite nonsense, thus unavoidably leads to the catastrophe.
Related to Reasoning in Deriving the Ultraviolet Catastrophe
1. What is the Ultraviolet Catastrophe?
The Ultraviolet Catastrophe is a phenomenon in physics where the classical theory of thermal radiation predicted an infinite amount of energy to be emitted at short wavelengths, which contradicted experimental observations.
2. How did scientists use reasoning to derive the Ultraviolet Catastrophe?
Scientists used the classical theory of thermal radiation, which stated that the energy of a blackbody radiation increases with the frequency of light. They then applied this reasoning to the ultraviolet region and found that the predicted energy was infinite, leading to the Ultraviolet Catastrophe.
3. What was the significance of the Ultraviolet Catastrophe in the history of physics?
The Ultraviolet Catastrophe led to the development of quantum mechanics and the understanding that energy is quantized, rather than continuous. This revolutionized the field of physics and paved the way for further discoveries and advancements.
4. How did Max Planck's theory of quantum mechanics solve the Ultraviolet Catastrophe?
Max Planck proposed that energy is not continuous, but rather comes in discrete packets called quanta. This theory successfully explained the observed behavior of thermal radiation and resolved the infinite energy problem of the Ultraviolet Catastrophe.
5. Is the Ultraviolet Catastrophe still a relevant topic in modern physics?
While the Ultraviolet Catastrophe has been resolved by the development of quantum mechanics, it is still studied and referenced in modern physics as an important event in the history of the field. It serves as a reminder of the limitations of classical theories and the importance of constantly questioning and improving our understanding of the world.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Classical Physics
