Reciprocals and repeating digits
  • Thread starter guysensei1
In summary, reciprocals are numbers that result in a product of 1 when multiplied together. To find the reciprocal of a number, divide 1 by that number. Repeating digits are numbers with a repeating pattern after the decimal point, and are represented using a bar over the pattern in mathematical notation. To convert a repeating decimal to a fraction, the decimal represents a fraction with the repeating pattern as the numerator and the number of repeating digits as the denominator.
guysensei1
31
So when you take the reciprocals of integers, some have nice non repeating decimal forms like 0.5 and 0.2, but of course a lot of them give infinite repeating strings.
1/7 gives 0.142857 repeating, so there are 6 digits repeating.
1/12 give 0.083333... but there is only 1 digits that's repeating, which is 3.
Which integer reciprocal gives the most digits repeating? Or is there no answer?
Mathematics news on Phys.org
Consider the sequence ##\frac19, \frac{1}{99}, \frac{1}{999}, \frac{1}{9999},\ldots##
FAQ: Reciprocals and repeating digits
What are reciprocals?
Reciprocals are numbers that, when multiplied together, result in a product of 1. For example, the reciprocal of 2 is 1/2, and the reciprocal of 3 is 1/3.
How do you find the reciprocal of a number?
To find the reciprocal of a number, simply divide 1 by that number. For example, to find the reciprocal of 4, you would divide 1 by 4, resulting in 1/4.
What are repeating digits?
Repeating digits are numbers that have a repeating pattern of digits after the decimal point. For example, the decimal representation of 1/3 is 0.333333..., where the 3s repeat infinitely.
How do you represent repeating digits in mathematics?
Repeating digits are represented using a bar over the repeating pattern. For example, the repeating decimal 0.333333... would be written as 0.3̅ in mathematical notation.
How do you convert a repeating decimal to a fraction?
To convert a repeating decimal to a fraction, we can use the fact that the decimal represents a fraction with the repeating pattern as the numerator and the number of repeating digits as the denominator. For example, 0.3̅ is equivalent to 3/9, which can be simplified to 1/3.
