PAllen
- 2,543
It seems part of this disagreement is terminological. To me, coordinates are system of labels covering a region; in contrast to measurements of distances, time intervals, and angles which I view as invariants. To me, stating that several instruments are each feeling no accelerations (measured with ideal accelerometers) and collectively maintaining fixed relative positions is part of the recipe for measurement; placing this in an inertial frame or coordinates is simply one way of describing the set up. Stating that a measurement comes out the same wherever, whenever, at any relative speed to something else, and in what orientation you do it is describing an invariant symmetry. [In this sense, I would correct my statement that you can't verify Lorentz invariance, meant as this collection of symmetries.] So, basically, all the things I define as geometric or physical invariants independent of coordinates or frames, Samshorn is bundling into an (to me) extended concept inertial frames.I don't see a constructive way to continue with such different definitions. I do see that the value in my approach is to separate concepts I consider invariant and coordinate independent from features of particular systems of labels, because I have seen much confusion in this area.
