I Recovering Hamilton's Equations from Poisson brackets
The discussion centers on the derivation of Hamilton's equations from Poisson brackets, highlighting a critical oversight in a referenced text that assumes the partial derivatives of dynamical variables with respect to time are zero. This assumption leads to confusion, as the variables are indeed functions of time, and their time derivatives cannot be disregarded. The author attempts to clarify this by introducing a mathematical framework that incorporates these derivatives, emphasizing that the equations can only be recovered if the time derivatives are treated appropriately. A suggestion is made to reconsider the textbook used, as it may not adequately address this fundamental aspect. Ultimately, the conversation underscores the importance of accurately accounting for time dependence in dynamical systems when applying Hamiltonian mechanics.
brotherbobby
TL;DR Summary
The online lecture notes I am following (see screenshot below) (correctly) derives the time derivative of a dynamical variable ##u(q,p,t) = \{u,H\}+\dfrac{\partial u}{\partial t}##.
It then takes in stages, ##u=\q_i## and then ##u = p_i## to find Hamilton's equations of motion, if only as a form of reassurance. Namely, ##\dot{q}_i = \partial H/\partial p_i\quad \dot{p}_i=-\partial H/\partial q_i##. But there's a serious problem in the derivation.
The issue : Let me start by copying and pasting the relevant passage from the text, thanks to modern day methods of computing.
The trouble is, in equation (4.79), it completely ignores the partial derivative of ##q_i## with respect to time, i.e. it puts ##\partial q_i/\partial t=0##.
But ##q_i## is a dynamical variable of ##t##, or ##q_i(t)##. In the derivation of Hamilton's equations from the Hamiltonian, viz. ##H = p_i \dot q_i-L##, nowhere did we assume that ##\partial q_i/\partial t=0##.
It goes on to the do the same (next page, 70) with the second Hamilton's equation, putting again ##\partial p_i/\partial t=0##.
Question : Clearly, these partial derivatives are not zero. And yet, if we don't put them to zero, Hamilton's equations are not recovered.
What is going on?
Attempt :
Let me try to "fill in" the mathematics that the author has left out, with the first equation.
##\small{\dot{q}_i=\{q_i,H\}+\partial q_i/\partial t=\partial q_i/\partial q_j \partial H/\partial p_j- \partial q_i/\partial p_j \partial H/\partial q_j+\partial q_i/\partial t=\delta_{ij}\, \partial H/\partial p_j+\partial q_i/\partial t=\partial H/\partial p_i+\partial q_i/\partial t\ne \partial H/\partial p_i\;\text{unless}\; \partial q_i/\partial t=0}##.
Request : Is ##\partial q_i/\partial t=0##? A help or a hint would be most welcome.
Such a way of presentation can really confuse a reader.
In (4.76) the function u depends on p,q and t. But in formulas (4.77) and (4.78) it is assumed that u=u(p(t),q(t),t) where p(t),q(t) is a solution to the Hamilton equations.
brotherbobby said:
The trouble is, in equation (4.79), it completely ignores the partial derivative of qi with respect to time, i.e. it puts ∂qi/∂t=0.
that is because of that ##u(p,q,t)=q_i## does not depend on t explicitly. In such cases I usually recommend changing a textbook.
UPD
We can look at this as follows.
For functions f(t,q,p), g(t,q,p) introduce a Poisson brackets:
$$\{f,g\}:=\frac{\partial f}{\partial q}\frac{\partial g}{\partial p}-
\frac{\partial g}{\partial q}\frac{\partial f}{\partial p}.$$
Particularly if ##f=q_i## then
##\{q_i,g\}=\frac{\partial g}{\partial p_i}## . Thus the Hamilton equations can be presented as follows
##\dot q_i=\{q_i,H\}##
analogously
##\dot p_i=\{p_i,H\}##
brotherbobby said:
.Request : Is ##\partial q_i/\partial t=0##? A help or a hint would be most welcome.
@brotherbobby Equation (4.78) in your notes is valid for functions defined on the phase space, like ##u=u(q,p,t)##. For such functions, the independent variables are taken to be ##q##, ##p## and ##t##. Therefore, if you want to use Eq.(4.78) to calculate total time derivative of ##q##, you need to formally treat ##q## as a function defined on phase space - in this case you see that the particular phase space function ##u(q,p,t)=q## does not depend on time explicitly (since the independent variables for functions ##u(q,p,t)## are ##q##, ##p## and ##t##), hence the partial time derivative of this phase space function is zero. Thus you recover the Hamilton's equations.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
