A Recurrence relations for series solution of differential equation
dim_d00m
TL;DR Summary
I'm looking for a three-term relation between the coefficients of a series solution to the spheroidal harmonics defining equation.
I am currently looking at section IIA of the following paper: https://arxiv.org/pdf/gr-qc/0511111.pdf. Eq. (2.5) proposes an ansatz to solve the spheroidal wave equation (2.1). This equation is
$$ \dfrac{d}{dx} \left((1-x^2) \dfrac{d}{dx}S_{lm} \right) + \left(c^2x^2 + A_{lm} - \dfrac{m^2}{1-x^2}\right)S_{lm}=0,$$
and the ansatz is
$$S_{lm}(x)= e^{cx}(1-x^2)^{|m|/2} \sum_{p=0}^{+\infty} a_p (1+x)^p.$$
Upon differentiating this ansatz and some algebra, I find the following equation:
$$ \sum_{p=0}^{+\infty} a_p (1+x)^p \left[ -2c(1+|m|)x(1+x^2) + c^2(1-x^2)^2 + |m|\left( (|m|+1)x^2 -1 \right) +(1-x^2)(c^2x^2+A_{lm}) -m^2 \right] + \sum_{p=0}^{+\infty} (p+1) a_{p+1} (1+x)^p \left[2x(1-x^2)^2 - 2(1+|m|)(1-x^2) \right] +\sum_{p=0}^{+\infty} (p+2)(p+1) a_{p+2} (1+x)^p (1-x^2)^2 =0. $$
Expanding and grouping powers of $x$, I get
$$\sum_{p=0}^{+ \infty} (1+x)^p \left[a_p[A_{lm} + c^2 - m(m+1) -2xc(m+1) + x^2(m(m+1)-c^2 -A_{lm}) + 2x^3 c (m+1)] \right]\\
+ 2(p+1) a_{p+1} [c- (m+1)x - 2cx^2 + (m+1)x^3 + cx^4] + (p+2)(p+1)a_{p+2}[1-2x^2+x^4]=0.$$
I have no idea how to proceed further. I've tried to look at equating the coefficients of the various powers of ##x## to 0, but I don't get anything like the recurrence relation outlined in Eqs. (2.6) and (2.7) of said paper. Any help would be much appreciated!
Welcome to PF!
The basic idea with series solutions is to substitute into the DE, collect like powers of ##x## , and then equate the coefficient of each power of ##x## to zero. Doing this leads to the mess you've shown. Now, the authors have reduced this with perseverance (and or a computer algebra package) leading to the recurrence relations (2.6) and (2.7). Okay, starting with these recurrence relations, one needs to specify ##a_0## then use (2.6) to get ##a_1##. From here (2.7) may be used to find ##a_2## and so on. Sadly, this is where the real work starts.
The differential equation (2.1) has singular points at ##x = \pm 1##. The expansion, (2.5) is being taken around ##x=-1## so you will get an analytic solution valid in a region around ##-1##. The problem is the point ##x=1##. For almost all values of ##A_{lm}## the series will diverge at ##x=1##. The series will only converge for eigenvalues. Now, they solve this problem in equation (2.9). I have no clue how they arrived at this continued fraction. I'd be interested to find out.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
